Latch circuits based on transistors, to switch on and off a load with a momentary input signal
A latch circuit is supposed to lock on and off a load (such as a relay coil or a led light), through a momentary input signal.
At the start condition both transistors and the led light are off, so at the node 2 we have a positive signal.
When you press the button both transistors are enabled, but the coil keeps off because it is supplied by 2,5 Volts.
View all 2 project logs
Electroniclovers123
Dejan Vasić
Jercio LED
Steph
Yes, delete it Cancel
You are about to report the project "Latch circuits", please tell us the reason.
