The case
A project log for Compact accelerometer for experiments
This device is a battery powered, usb connectable accelerometer with onboard memory, planned for experimental use in basic physics lessons
vayVay 09/12/2017 at 12:200 Comments
The case is made out of 4 layers of 3mm acrylic, a small sheet of 1,2mm plastic to hold the pcb in place and 4 3mm vinyl screws and bolts. The bottom layers got some cutouts to make room for the lipo cell and to safe weight. Everything is drawn in Autocad and cut out with an lasercutter.
