The coaster part of the project had been bugging me all the way through this project but I thought I would figure it out when I got to the end of the project. I needed this part to be strong that's why I used an 3mm think piece of aluminium which was over kill but I wasn't taking any chances. I also decided to use a 2mm thick piece of perspex because it had to be see through. I also needed this part to be water proof because as we all know condensation forms on the outside of a ice cold drink. I was thinking of using bolts and tapping the aluminium on the button to sandwich the WS2812 LED's between the layers.
I had a stroke of genius and decided to use some clear silicon adhesive because this would make it water proof and stick it all together without having to use bolts and taps
![](https://cdn.hackaday.io/images/4065031506249998051.jpg)
Here it is with a heavy weight to make sure its stuck well
