![](https://cdn.hackaday.io/images/6517101459701585139.jpg)
In no particular order, different versions of what I'd like the case to look like. Testing before injection molds are made is easy when you have a 3d printer :D
A project log for Zamek: The Offline Pocket Password Manager
Creating and retrieving passwords for all your accounts has never been this easy and convenient!
Have you considered adding some more, hmm, design to it? Like making it look a little bit like a castle tower (or a tower chess piece), or at least rounding off one corner, to break the symmetry, etc.? Even a simple brick pattern could improve the looks greatly.
the final design will be much more designed :) these were just the protective enclosures for testing fit
