//Will Yates - NeoPixel_Simple
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_gpio.h"
#include "inc/hw_ints.h"
#include "inc/hw_types.h"
#include "inc/hw_memmap.h"
#include "inc/hw_ssi.h"
//#define PART_TM4C123GH6PM
#include "driverlib/pin_map.h"
#include "driverlib/qei.h"
#include "driverlib/gpio.h"
#include "driverlib/sysctl.h"
#include "driverlib/rom.h"
#include "driverlib/ssi.h"
#include "driverlib/udma.h"
#define NUM_LED 6
#define LED_PORT GPIO_PORTA_BASE
#define LED_PIN GPIO_PIN_7
#define TLV2553_PORT GPIO_PORTE_BASE
#define TLV2553_CS GPIO_PIN_0
#define TLV2553_EOC GPIO_PIN_5
#define NRF24_PORT GPIO_PORTA_BASE
#define NRF24_CSN GPIO_PIN_4
#define NRF24_CE GPIO_PIN_3
#define NRF24_IRQ GPIO_PIN_2
// TLV2553 Commands
uint32_t chan_0 = 0b000000000000; // SELECT analog input channel 0
uint32_t chan_1 = 0b000100000000; // SELECT analog input channel 1
uint32_t chan_2 = 0b001000000000; // SELECT analog input channel 2
uint32_t chan_3 = 0b001100000000; // SELECT analog input channel 3
uint32_t chan_4 = 0b010000000000; // SELECT analog input channel 4
uint32_t chan_5 = 0b010100000000; // SELECT analog input channel 5
uint32_t chan_6 = 0b011000000000; // SELECT analog input channel 6
uint32_t chan_7 = 0b011100000000; // SELECT analog input channel 7
uint32_t chan_8 = 0b100000000000; // SELECT analog input channel 8
uint32_t chan_9 = 0b100100000000; // SELECT analog input channel 9
uint32_t chan_10 = 0b101000000000; // SELECT analog input channel 10
uint32_t test_1 = 0b101100000000; // SELECT TEST, Voltage = (VREF+ + VREF-)/2
uint32_t test_2 = 0b110000000000; // SELECT TEST, Voltage = REFM
uint32_t test_3 = 0b110100000000; // SELECT TEST, Voltage = REFP
uint32_t SW_PD = 0b111000000000; // SW POWERDOWN (analog + reference)
uint8_t bit_8 = 0b000001000000;
uint8_t bit_12 = 0b000000000000;
uint8_t bit_16 = 0b000011000000;
uint8_t msb = 0b000000000000;
uint8_t lsb = 0b000000100000;
uint8_t unipolar = 0b000000000000;
uint8_t bipolar = 0b000000010000;
//These two functions translate the 24bits for each LED to something that //
//the WS2812b LEDs can understand. The datasheet is useless // // ________ //
// |_____ '1' is a 800ns pulse then low (can be high forever) //
// |________ '0' is a 400ns pulse (only key pulse lengt ) //
// the only thing that really matters is that the high pulses dont overlap //
void Pixel_High() // function for sending a high pulse
GPIOPinWrite(LED_PORT, LED_PIN, LED_PIN);
SysCtlDelay(3); //this needs to be the equv of 800ns (ish)
GPIOPinWrite(LED_PORT, LED_PIN, 0x00);
SysCtlDelay(3); //length of this doesn't really matter
void Pixel_Low() // function for sending the low pulse
{ // switching the pin on and off takes the proper amount of time
SysCtlDelay(4); //length of this doesnt really matter
void clear_Ring()
//write the same value to all the LEDs
int clear;
int count;
for(clear = 0; clear<NUM_LED; clear++){
//Green
for (count = 0; count < 8; count++){
Pixel_Low();
//Red
Pixel_Low();
//Blue
Pixel_Low();
void config_LED()
//Enable GPIO port
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // SYSCTL_PERIPH_GPIOF * blinky *
while(!SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOA)) // SYSCTL_PERIPH_GPIOF * blinky *
GPIOPinTypeGPIOOutput(LED_PORT, LED_PIN);
//reset pixels
clear_Ring();
SysCtlDelay(10000);
#include <SPI.h>
#include "Arduino.h"
const int dataReadyPin = PA_5;
const int chipSelectPin = PE_0;
// TLV2553 Commands
uint16_t chan_0 = 0b000000000000; // SELECT analog input channel 0
uint16_t chan_1 = 0b000100000000; // SELECT analog input channel 1
uint16_t chan_2 = 0b001000000000; // SELECT analog input channel 2
uint16_t chan_3 = 0b001100000000; // SELECT analog input channel 3
uint16_t chan_4 = 0b010000000000; // SELECT analog input channel 4
uint16_t chan_5 = 0b010100000000; // SELECT analog input channel 5
uint16_t chan_6 = 0b011000000000; // SELECT analog input channel 6
uint16_t chan_7 = 0b011100000000; // SELECT analog input channel 7
uint16_t chan_8 = 0b100000000000; // SELECT analog input channel 8
uint16_t chan_9 = 0b100100000000; // SELECT analog input channel 9
uint16_t chan_10 = 0b101000000000; // SELECT analog input channel 10
uint16_t test_1 = 0b101100000000; // SELECT TEST, Voltage = (VREF+ + VREF-)/2
uint16_t test_2 = 0b110000000000; // SELECT TEST, Voltage = REFM
uint16_t test_3 = 0b110100000000; // SELECT TEST, Voltage = REFP
uint16_t SW_PD = 0b111000000000; // SW POWERDOWN (analog + reference)
uint16_t bit_8 = 0b000001000000; // Configuration bits[3:2] {01: 8-bit output,
uint16_t bit_12 = 0b000000000000; // 00: 12-bit output,
uint16_t bit_16 = 0b000011000000; // 10: 12-bit output,
// 11: 16:bit output}
uint16_t msb = 0b000000000000; // Configuration bits[1] {0: MSB out first,
uint16_t lsb = 0b000000100000; // 1: LSB out first}
uint16_t unipolar = 0b000000000000; // Configuration bits[0] {0: Unipolar binary,
uint16_t bipolar = 0b000000010000; // 1: Bipolar 2's complement}
uint16_t val_null, val0, val1, val2, val3, val4, val5;
SPIClass TLV2553(2);
void setup()
Serial.begin(9600);
TLV2553.begin();
//TLV2553.setDataMode(0);
//TLV2553.setClockDivider(128);
// initialize the data ready and chip select pins:
pinMode(dataReadyPin, INPUT);
pinMode(chipSelectPin, OUTPUT);
digitalWrite(chipSelectPin, HIGH);
void loop()
while (!digitalRead(dataReadyPin))
digitalWrite(chipSelectPin, LOW);
val_null = TLV2553.transfer((chan_0 | bit_12 | msb | unipolar) >> 4);
while (digitalRead(dataReadyPin)){
val_null = (val_null << 4);
val_null += TLV2553.transfer(0xF) >> 4;
val0 = TLV2553.transfer((chan_1 | bit_12 | msb | unipolar) >> 4);
val0 = (val0 << 4);
val0 += TLV2553.transfer(0xF) >> 4;
Serial.print("A0: ");
Serial.println(val0);
val1 = TLV2553.transfer((chan_2 | bit_12 | msb | unipolar) >> 4);
val1 = (val1 << 4);
val1 += TLV2553.transfer(0xF) >> 4;
Serial.print("A1: ");
Serial.println(val1);
val2 = TLV2553.transfer((chan_3 | bit_12 | msb | unipolar) >> 4);
val2 = (val2 << 4);
val2 += TLV2553.transfer(0xF) >> 4;
Serial.print("A2: ");
Serial.println(val2);
val3 = TLV2553.transfer((chan_4 | bit_12 | msb | unipolar) >> 4);
val3 = (val3 << 4);
val3 += TLV2553.transfer(0xF) >> 4;
Serial.print("A3: ");
Serial.println(val3);
val4 = TLV2553.transfer((chan_5 | bit_12 | msb | unipolar) >> 4);
val4 = (val4 << 4);
val4 += TLV2553.transfer(0xF) >> 4;
Serial.print("A4: ");
Serial.println(val4);
val5...
