Arduino controlled door trigger light bulb
I always forget to turn off the light, no longer bother to turn the lights
When the door is opened the relay pulls,
If the door is closed wait 10 seconds and leave the role.
View all 9 components
  • 1
    Step 1
    Source code:
    int rolePin = 2; // pin that connects the relay
    int magnetPin = 3; // pin that connects magnetic switches
    int wait = 10000; // time to turn off light (in milliseconds)
    boolean doorStatus = false;
    void setup() {
    pinMode(rolePin, OUTPUT);
    pinMode(magnetPin, INPUT_PULLUP);
    void loop() {
    int magnetState = digitalRead(magnetPin);
    if (magnetState == HIGH) {
    digitalWrite(rolePin, HIGH);
    doorStatus = true;
    else{
      if (doorStatus == true) {
    delay(wait);
    digitalWrite(rolePin, LOW);
    doorStatus = false;
    delay(5);
View all instructions
