CHS Doorbell
Plays the theme of my favourite cartoon as you enter the room
This device is based on the low cost ISD1820 sound module. It can be found at various places in the internet for about 4 USD.
  • 1 × ISD1820 Sound Module 4 USD, 10 second recording time, needs 3 to 5 Volt power supply
  • 1 × 2AA battery holder
  • 1 × tactile switch OR reed switch Triggers the playback
  • 1 × (optional) power switch to turn off the device
  • 1 × (optional) case Protects the device and adds coolnessw
View all 6 components
  • 1
    Step 1
    Wiring is pretty simple. Solder two wires to the battery holder. If you have a female 2.54mm pin header you can solder it to wires. Alternatively you can directly solder the wires to the pins on the board. Positive (+) goes to VCC and negative (-) to GND.
View all instructions
