Following the impulse
A project log for Recycled LiPo Powerbank / PSU
Just a quick skull-wrenched module-based pack of extra juice and converters
davedarkodavedarko 03/31/2015 at 15:440 Comments
I designed an additional case for the banana plug connectors and chemically welded it with an acetone/abs solution to the case. When the 12V converter arrives, I will connect those plugs the following way: GREEN - LiPo Out, RED is 5V and yellow is 12V.
I may add a second cell to get even more power but want to safely load the cells so I want to have two LiPo chargers.
