Enclosure
A project log for Reliable 10MHz GPSDO on the cheap
Building a relatively compact and precise 10MHz Clock source from spare parts & Ebay components for less than ~100$.
moonlandingMoonLanding 04/29/2015 at 23:080 Comments
Purchased on Ebay a nice extruded aluminum enclosure, and mounted the (also ebay) ISOTEMP OCXO (10MHz). The mounting is free-floating: simply foam surrounding the crystal - tight enough for it to not shift or move around. Foam is glued to the enclosure with Gorilla PU style glue.
