Cavity measurements with dielectric
A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
paul-kocylaPaul Kocyla 04/22/2016 at 19:566 Comments
The EMDrive V4 got a modification.
I inserted a 3D-printed dielectric on the big end - which showed significant performance boost in another (not my) test on a 900 MHz thruster.
I recorded a 5 values/s sweep from 22.5 GHz to 25.5 GHz without dielectric and I´m just now recording the same sweep wiith the dielectric inside. I will post the data when it´s finished.
Ok, here is the comparison no_dielectric/with dielectric
Add. Info: Curve is named "Sensor", it´s arctan(IFQ/IFI), but it´s just the ADC values, so there is an overall characteristic which the curve is not normalized to.
In case you complain about not labeled axes again ;)
willemstaal wrote 04/25/2016 at 07:54 point
Great results! You can also consider a piece of glimmer or mica as dielectric. As glimmer is a package of sheets that are easy detachable , you can experiment with different layer thicknesses. You can find glimmer in old heaters.. High power condensers still use it as dielectric.
Marcus Menghini wrote 04/24/2016 at 14:36 point
If you got the chance, could you redo the test with a dielectric made of PTFE or HDPE? Thanks again!
Paul Kocyla wrote 04/24/2016 at 14:39 point
And when do I sleep? I think I´ll run more tests on ABS and will meanwhile prepare the PocketQub.
Marcus Menghini wrote 04/24/2016 at 13:13 point
Good work! Can you tell us what material you are using for your dielectric? Thanks!
Paul Kocyla wrote 04/24/2016 at 13:23 point
It´s 3D-printed with ABS, 3mm thick
Marcus Menghini wrote 04/24/2016 at 13:55 point
Thanks! Was it with full infill settings?
