Milling and assembling
A project log for The "Woodcopter"
Making of my Plywood Quadcopter.
hebel23hebel23 07/21/2015 at 18:520 Comments
The new arms are made of 10mm plywood instead of 4mm in the first version. The frame itself is made of 6mm plywood.
The arms can be collapsed. So you can pack the copter to save space.
