open source development board for nRF51822 Core stackable board and BLE Inertial Measurement Unit shield project
Initial tests of the board look promising. nRF51822 seems to respond properly. Now for our 9+DOF board.
Stickvise rocks - soldering made so much easier!
Design files for the board are available here.
I had a similar problem with a Onion Omega2 board, which came in 2mm pin spacing.
I found this cheap proto board on Aliexpress "Prototype PCB for Arduino UNO R3 Shield Board DIY, Combo 2mm + 2.54mm Pitch", which allowed me to make an adaptation between 2mm and 2.54mm:
https://fr.aliexpress.com/item/32895744627.html
