Programing the HX1K
A project log for ICEd = an Arduino Style Board, with ICE FPGA
DIPSY-EPT Emulator and Programme Tool - Open Source Hardware for Open Source FPGA Toolchain
antti-lukatsAntti Lukats 08/10/2015 at 20:190 Comments
Connect USB Cable, set 3 jumpers 1-2, 3-4, 5-6, click detect, see this in Diamond Programmer:
Change LP1K to HX1K manuall, select BIN file to load into HX1K FPGA Configuration RAM, click on program..
FPGA is configured and should live.
Programming the SPI Flash is as easy too, there are 2 jumpers to be changed and then proper SPI Part has to be selected:
When this succeeds, then FPGA will load itself from SPI Flash on power up on reset event. Creating multiboot images is a bit more complicated, but that has time to be explained in next updates.
