To house all the electronics, I needed a plastic shell. Actually, several plastic shells; one for the high voltage oil tank, one to hold an x-ray tube, one to hold aluminum filters, one to hold the high voltage oil tank, a handle to hold everything... it goes on!
To design these, I broke out my favorite CAD suite: Autodesk Inventor. I also broke out the caffeine, and spent some 14 days staring into inventor, to design the following *injection moldable :D* parts
A model of my chosen x-ray tube:
![](https://cdn.hackaday.io/images/4845421439614433741.png)
A shell to hold the tube, and a lead jacket around it:
An oil tank, to hold the tube, the shell, and its wrapping:
A lid for the oil tank, and a rubber chamber to allow for thermal expansion:
Aluminum filters of different thicknesses, and a disk to hold them in place:
A shell to hold the oil tank, and other parts:
Sides, and a handle to allow for easy carrying.
An LCD, and PCBs to hold components, buttons, and the voltage multiplier:
And finally, a top shell and a rubber flippity-flap to cover the power receptacle:
______ _ ______ _ | ___ \ | | | ___ (_) | |_/ / __ _ __| | __ _ | |_/ /_ _ __ __ _ | ___ \/ _` |/ _` |/ _` | | ___ \ | '_ \ / _` | | |_/ / (_| | (_| | (_| | | |_/ / | | | | (_| | \____/ \__,_|\__,_|\__,_| \____/|_|_| |_|\__, | __/ | |___/
Then came the 3D printing, the long, torturous 3D printing.
Some people have trouble with parts peeling off, but often, I have the exact opposite problem. x_x
