AutoRechargableBattery
0 followers
Battery auto rechargable as a ancient system this battery can recharged himself
MECHANICUS wrote 08/23/2015 at 20:00 point
This maybe?
Bruce Land wrote 08/23/2015 at 11:45 point
recharge via Brownian motion is a second-law perpetual motion machine
MECHANICUS wrote 08/23/2015 at 20:08 point
Is a thermopile second order perpetual motion? No they generate output voltage due to a temperature difference.
I respectfully disagree, that Brownian motion is perpetual motion. Recharge via Brownian motion is a real observable phenomenon the input energy is heat from the environment. Asymmetric electrodes can be tuned to have pores suited to certain ions. They demonstrate an electrolytic double layer by intercalating the ions asymetrically in the electrodes.
As, I said before the effect is so minuscule and the lack of energy density makes the cell useless besides being a trinket.  If it could be made better it could be used to recycle waste heat from a steam power plant.
Bruce Land wrote 08/24/2015 at 11:34 point
Ah, an temp difference, then there is no problem.
Brownian motion at constant temp cannot work.
MECHANICUS wrote 08/30/2015 at 04:18 point
Yes I will build one to demonstrate using asymmetric carbons, I really don't have a clue how or why it works, I highly doubt there is a daemon involved:)
Bruce Land wrote 08/22/2015 at 21:44 point
Another perpetual motion machine?
MECHANICUS wrote 08/22/2015 at 22:30 point
Well there is such a thing as a Karpen cell that can recharge due to brownian motion. The recharge rate is so low and the energy density miniscule that it doesn't make any sense.
Edit: But if he can improve on it I am all eyes.
