The program counter (a presettable 6-bit up-counter) has been completed:
![](https://cdn.hackaday.io/images/1905231503796209757.jpg)
Testing in progress...
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
Looks a lot nicer and faster than what I am working on. Keep up the great work :-)
I wouldn't say mine necessarily looks 'nicer'...we have chosen different aesthetic approaches (and substrates) :) Cardboard and brass tacks capture that 'cyberpunk' spirit - I really like it
It should be good for at least a several hundred kHz. It's a synchronous counter, which helps. I'll know in a day or so.
How fast do you think it will count? (I know you're still testing it ;-)
