Become a member to follow this project and don't miss any updates
Stubby the (Teaching) Hexapod
100% open source robot platform with accessability and affordability in mind: teaching children of all ages about robots & programming
40 215 146
Share on twitter   Share on Facebook
This project was created on 04/09/2014 and last updated 4 days ago.
Description
Stubby is a 100% open source, extensible robotics platform. It features ultra low cost design (MDF frame, which you can cut with a scroll saw; $2 low torque servos; a single microcontroller; easily-obtainable electronic and mechanical components), can be controlled by a Universal Controller (over XBee) or a computer (over Bluetooth), and has a Processing API which can help children learn basic programming concepts.
My daughter, Princess Sparkle, and I have been working on it since February 2014, along with the help of some of my friends. Other hackers worldwide are working on their own versions, some of which are 3D printed, others are laser cut plexiglass, and at least one is hand cut from Baltic Beech wood for what will doubtless turn out with a beautiful, natural look.
The Universal Controller interface is completed and working, and the Processing / Bluetooth API is well underway.
See http://stubby.digitalcave.ca/ for more information.
Details
Since we started, Stubby has grown from a simple, direct-driven 2 DOF (degree of freedom) per leg frame to a mechanically-assisted 3 DOF per leg design with a full inverse kinematics engine (which allows the processor to calculate custom foot positions for each step, rather than relying on a static loop).
This video shows off the latest version, including various features of the Inverse Kinematics engine:
Originally, the concept of Stubby came from the SG-1 universe's replicators (which, let it be known, are completely awesome!).  The name 'Stubby' was coined by Princess Sparkle, after seeing the first version (with 2cm long, oblong legs), barely able to limp along the carpet.
After the interesting parts (most notably the frame design and inverse kinematics engine) were completed, I wanted to expand Stubby's abilities.  The Hackaday Prize made me think about 'connected' projects... at the same time, Princess Sparkle was expressing interest in computers and programming.  In talking with her, we came up with the idea of making an API which would allow her to issue simple commands to control the robot.
This is not the first time she has done this sort of thing... in her Grade 1 class, there was a unit on Lego Mindstorms robots, which taught the children to visualize arithmetic expressions by programming the robot to, for instance, move 10 units forward and 3 units back, and seeing where on a number line they were (10 - 3 = 7).  With Stubby, the plan is to expose more of the programming structure to her, teaching such things as procedural control, calling methods, assigning variables (by reading sensors), etc.
When finished, I plan on having an Ultrasonic Distance sensor and a magnetometer, together allowing users to write code for autonomous operation.  An array of UV LEDs + photodiodes on the bottom will allow for writing line following algorithms.  An i2c header is broken out, so that hackers can add completely new components as well.
Please refer to Youtube for THP Submission video and THP Semifinals video.  Judges: see the Semifinals Requirements log for details on how Stubby achieves THP requirements.
For those who are interested in building their own version of Stubby, I have all the designs, plans, and theory available for all to use and modify freely.  There are two documents which encapsulate the majority of my work.
First are the frame plans. The frame is one of the biggest advantages which Stubby holds over other, more expensive hexapods.  The first difference is the materials: Stubby is designed to be cut from 1/4" MDF using a scroll saw.  (However, the design is adaptable enough to be able to use other materials as well, and the community has modified these plans for use with a 3D printer, laser cutter, etc.)  The frame is quite easy to make; simply print the plans, tape it to an 8.5x11" sheet of MDF, and cut along the lines.  The second difference is how the servos are attached to the legs: Stubby uses push rods to convert distance to torque, allowing Stubby to work with cheap, low-torque servos (at the expense of being a bit more limited in leg movement).  This is the biggest factor in being able to keep below $150 in components (this assumes you have no parts in your parts bin, but does assume that you have all the required tools already).
The second important diagram is the circuit board schematic. This shows how to wire the control board so that the microcontroller can perform the needed calculations and tell the servos how to move.
The hardware is useless without software to control it. You can download or browse my git repository, which includes all software, electronics, and frame design.
Everything needed to make Stubby, both hardware and software, is licensed under a Creative Commons Attribution-Share Alike License).
Components
  • 1 × *****SEE http://stubby.digitalcave.ca/stubby/components.jsp FOR BETTER FORMATTING*****
  • 1 × *****ELECTRONIC COMPONENTS (FOR REVISION 1.0 / 1.1 BOARDS)*****
  • 1 × ATMega 1284 Microcontroller (DIP package) (ATMEGA1284-PU-ND)
  • 1 × Control PCB (order from gerber files in git, or contact TheBigOne for possible extra boards)
  • 18 × 9g Micro Servos (from Hobby King, about $2.00 each at the time of this writing) I used "Turnigy TG9z 9g / 1.7kg / 0.12sec Eco Micro Servo"; similar specs / size should also work.
  • 1 × Some RF Serial link. I used XBee, but HC-05 Bluetooth modules or anything with a transparently connected serial port will work DK Part #XBP24-AWI-001-ND or XB24-AWI-001-ND or many similar ones
  • 1 × Universal Controller or other method of remote control
  • 1 × 3v3 LDO Regulator (MCP1702, Through Hole) (MCP1702-3302E/TO-ND)
  • 3 × 1uF Capacitors (1276-1066-1-ND) - Used for power supply + AREF decoupling
  • 10 × 1k Resistors (311-1.0KARCT-ND)
See all components
Project logs
  • Magnetometer Working
    4 days ago • 0 comments
    The magnetometer arrived on Thursday (yay for Adafruit and their speedy shipping!); today I spent most of the day getting it working.
    There were a few issues which I needed to overcome.
    First, I had to read the raw values over i2c.  This is easy enough; the only gotcha was that I didn't read the data sheet close enough, and I failed to notice that the axis are read in X, Z, Y order rather than X, Y, Z. (Really?!  I wonder if there is a technical reason for this ordering, or what ).
    After I got the raw values, I used atan2 to convert the x,y co-ordinates into an angle (heading).  The problem here was that (probably due to the magnetic fields of the servo motors) the Y axis was shifted very far down.  This meant that all the angles were being read as negative.  See a graph of the raw values below:
    By adding a constant offset to x and y, we got the readings to be properly centered around the origin.
    Next challenge was that I am operating in a magnetically noisy environment (there are 18 servos within centimeters of the magnetometer).  Implementing a low pass filter against headings is actually much harder than you would think.  (You have to remember the 'wrap around' at +/- PI).  In the end, I apply a low pass filter on the raw x, y co-ordinates.  A timer polls the magnetometer multiple times a second to ensure that the filtered heading is always accurate and up to date.
     Finally, once I had accurate, filtered headings available at any time, I was able to implement a simple PID algorithm which compares the actual heading to the desired heading and makes any required corrections to keep the robot on course.  This works very well: see for instance the video below, demonstrating the same programmed walk with and without using the magnetometer for course correction.
    Some of my next steps include:
    •  Use the magnetometer when turning in place to ensure that we turn to the correct angle
    • Add an auto calibration routine, which will be saved to EEPROM, so that we don't need to hard code the x,y offsets (which will likely be different for each robot anyway).
    • Provide access to the raw magnetometer heading from the Processing API (corrected for mounting angle)
  • Third party build now working!
    7 days ago • 0 comments
    Petr H. has just finished his beautiful plexiglass Stubby build (at least enough to get it walking around).  There is still a lot of cleanup and stuff to do, but everything seems to be working.  To my knowledge, he is the first person to have completed their own version of Stubby (if someone else has completed their own version, I would love to hear about it).
    He is controlling it with a Universal Controller, using two Bluetooth modules instead of XBees (a very good idea, as it keeps the cost down and allows for computer control without switching hardware).
    His latest pictures are below, and he will hopefully be sharing a video in the not too distant future:
  • More Third Party Builds
    8 days ago • 0 comments
    Stanisław K is also working on his own version of Stubby.  He has plans to eventually scale up the size to support larger servos, but initially he has converted all measurements to metric (my version has the CAD drawings in metric, but it uses imperial for drill sizes due to USA / Canadian screw sizes, #6, #4, etc).
    Prior to actually making it, he has modelled the entire system in SolidWorks 2013.  An example of this modelling is below:
    Some other (very high resolution) plans he has created include: 3D body viewbody component listingexploded body view, and leg assembly (part 1 and part 2).
    If anyone is interested, he has sent me a large number of .stl files as well as updated .dxf files; he has also offered to provide the source SolidWorks files.  I can get any interested parties in touch with him.
View all 59 project logs
Build instructions
  • 1
    See http://stubby.digitalcave.ca/stubby/assembly.jsp for assembly instructions (Hackaday.io flat list style makes it hard to organize a hierarchy of build steps...)  However, if you really want to see it here, you can try to follow along below...
  • 2
    *****ELECTRONIC BOARD ASSEMBLY*****
    Currently this is dedicated to the Revision 1.0 / 1.1 boards.  This section is almost exclusively soldering.
  • 3
    Start with the 0805 passive components, like the resistors and capacitors.
    When soldering two pad SMD components, I found that the following approach worked best for me:
    • Start by tinning (melting a bit of solder) onto one of the pads on the PCB
    • Hold the component in place with tweezers
    • Touch the component / PCB pad with the iron, to melt the tinned solder. The component should now be stuck in place.
    • Put solder on the other pad. Use enough that there is a good solid connection to the board.
    • Go back to the first pad, and add more solder, such that it is about the same as the second.
See all instructions
RoGeorge wrote 7 hours ago null point
Just saw your video, nice work!
Maybe you could use an optical mouse with modified optics, in order to make the mouse sensor see under the hexapod instead of a usual mouse pad. That will be a good way to read the real movement path and distance.
Are you sure? [yes] / [no]
The Big One wrote 5 hours ago null point
Thanks!
The mouse thing is a great idea... I'll have to try pulling apart an old mouse and see what I can do with it. That would eliminate some of the 'fudge factor' I am currently using to measure distances (although once I have it set, it is actually very accurate).
Cheers
GoatZero wrote 12 hours ago null point
Hello again wyatt, here i come for round 2,
1 ) I already got most of the mechanical stuff ready, i have been writing an android app to control stubby from cellphones using bluetooth modules, i have been checking out the code from the controller, and just to make sure i understand this, my app would have to send exactly these signals via bluetooth so i would have to simulate several buttons using example ( button start 0x04 ) , also , according to the code you dont seem to have used the L/R buttons is there any reason of why? (i could use them to add some laser diodes)
2) I already cloned your repos using git, At the moment im using windows and having a bit of trouble using AVR GCC and AVRDude, i currently have limited access to an AVR dragon so im planning as an emergency in case I cant find a programmer to replace it on using it to burn my micros using the compiled hex files for both the controller and stubby, would it be to much to ask if you could upload both hexfiles? so i can burn it asap before i lose access to this programmer?
3) About the new board (Blue one) and the all the bugfixes and edits at the code since the magnetometer was added, what are the chances of the code still running as intended in the 1.0 board (black one), will another revision of the board come? if not i might as well order a bunch of the blue one
4) i kind of want to make my own "stubby battle version" (yes, lasers) i have been looking for ways of putting even more weight down by replacing the eneloop batteries by some Lipo batteries, you seem to have worked with quad copters before , so i wanted your advice, in short how possible would it be to buy a 5v 20,000mAh batteries that weight less than the eneloops
5) just to be creepy I want to add a way of transmission of digital voice communication into stubby, example, using a mic placed in the controller and send the signal via xbee to stubby in order for it to replicate my voice 10m away from me using a speaker, (reason of why I need more battery power), I have been trying to find a way to accomplish this without altering that much the original circuit, but I still have to find a wait to doinig, im not sure this is possible using the BT modules but I believe it could be possible using the Xbees , I would like to know if you have any advice or documentation regarding this , before I start doing this,
Thanks for your time to answer the questions and all your effort into the project , im learning a lot just by trying to do what you have accomplished until know,
Cheers and GL in the semifinals
The Big One wrote 11 hours ago null point
Hello again, glad to hear about your progress!
1) Correct. Stubby currently uses a multi byte protocol to send / receive messages. The protocol is described in doc/protocol.txt. As for what messages you send, you have a few options there:
a) Emulate the Universal Controller messages
b) Emulate the Processing API messages
c) Implement your own controller (this is not nearly as hard as it sounds!)
Option a) would give you access to everything the Universal Controller can do: so, move in any direction, rotate, translate X / Y / Z, and pitch / roll / yaw.
Option b) would likewise give you access to everything the Processing API can do. As of today, that includes move a specified distance and turn to the specified angle, but more is being added daily.
Option c) would give you full control of what you can do. If you wanted to add a freakin' laser to Stubby's head, this is the way to do it. To do this, you would probably be best off to copy controllers/processing.*, call it "controllers/android" or something, and implement whatever features you want. If you do go this route let me know, and I can reserve a block of messages for the Android API use (for instance, messages in the range 0x00 - 0x0F are common to everything, 0x10 - 0x1F are for Universal Controller, 0x20 - 0x2F are for Processing API, 0x30 - 0x3F are for the (work in progress) Python Calibration program).
2) Send me an email (my email is on http://stubby.digitalcave.ca) and I can get you the current hex files. Keep in mind that this is very much a work in progress, and that things are changing daily, so if you can get a programmer, that would be best long-term. I bought a usbTinyISP from Adafruit a few years back and am loving it.
About the avr-gcc troubles... I found that it works best using version 4.8.1 (I have done it on Debian Jessie and Mac OSX using Crosspack. I don't have any Windows machines, so unfortunately I can't offer any suggestions there.
3) I currently have 3 (or maybe 4, depending on how you look at it) versions of the board:
-Rev 1.0 is the first one I ordered, and is what I am using now. It runs the microcontroller at 3.3v (and so is limited to about 12MHz). It is through hole with some larger SMD components, and can be soldered by hand with an iron (that's how I did it).
-Rev 1.1 (semi official) is identical to Rev 1.0 but with holes for a few capacitors added to help smooth power. I have not printed any of these, but I think that a few people who have printed their own have it.
-Rev 2.0 features a complete redesign of the power supply. The microcontroller runs at 5v (and so can be run at 20MHz), but there is still a 3.3v supply for peripherals. This board uses mostly SMD components, many of which are very small. I would not want to solder this one by hand with an iron; as soon as the boards arrive (I am hoping it will be this week), I plan on soldering it using a reflow method, with solder paste and a heat gun. To add a magnetometer, you will need to use an external one (I ordered one from Adafruit for $10, and it is working perfectly on my Rev 1.0 board)
-Rev 2.1 is a minor redesign of 2.0, and has a magnetometer on board. I have not ordered it yet, and have no immediate plans to do so. If I progress into the finals, this will be the board that would be used for a 'product' version.
Now, the obvious question at this point is which board to use? My suggestion is to consider whether you want to use a distance sensor or not, and whether you are comfortable doing fine pitch SMD soldering or not. The distance sensor is the only thing which cannot work on rev 1.x boards, since it requires a 5v supply. I plan on supporting all board revisions in the future (using #defines in the code), so there should be no problem with any of them.
4) I am not aware of any batteries which fit your specifications. LiPos do not come in 5v (they have a nominal voltage of 3.3v - 3.6v / cell, which means that a 1 cell battery is not nearly enough to power the servos, and a 2 cell battery is too high voltage and will damage the servos. If you are going to use a LiPo, you would need a regulator circuit as well, to regulate the voltage down to something between 4.8v - 6v. Linear regulators (i.e. 7806 (6v) or 7805 (5v)) could potentially work, but you would need to gang a few of them together to achieve the current needed for 18 servos, and you may not get great life out of the batteries since you need a couple of volts over the rated output. Plus, being a linear regulator, there would be a lot of wasted power (as heat). The alternative would be some sort of step down regulator, but max current is also a concern there.
In short, I am not aware of any better options than AA's at the moment, although I am keeping my eyes open for options.
5) That sounds like fun! :-) I have not tried transmitting audio over XBee or Bluetooth, (I have only used the serial ports on either of those), so unfortunately I can't help with this question at all. Sorry!
axf33480 wrote 24 days ago null point
magnifique réalisation du superbe travaille il et possible de le fair avec arduino
The Big One wrote 23 days ago null point
No it is not done with an Arduino; but it does use the same CPU family as Arduino does (the Atmel ATMega family of chips). A normal Arduino does not have enough pins to do what is required (drive 22 PWM signals), and the Arduino IDE is far too inefficient to do everything which needs to be done in real time.
Dan Royer wrote a month ago null point
I have open source java code to teach a crab robot to walk. https://github.com/MarginallyClever/hexapod If it helps your cause, please tell your friends about my work!
Jasmine wrote 2 months ago null point
Hello Wyatt and the Stubby team,
it looks like you've not updated the project in a couple of weeks. Now is the time to check and edit your project documentation on Hackaday Projects to give Stubby the best chance of going through to the next round of The Hackaday Prize.
I think you've got most of it covered, but this is the checklist of what must be on Hackaday Projects by August 20th:
- A video (check)
- At least 4 Project Logs (definitely check)
- A system design document. You have a lot of design docs. It would be great if you could highlight the main ones in the project Details.
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information in the project details.
Thanks for entering and good luck!
The Big One wrote a month ago null point
Thanks for the tips, Jasmine! I have updated the project details with the two most important diagrams (frame design and control board schematics), and duplicated the links from the links section describing the repository and what is included, and clarified the licensing.
Cheers
Souljacker wrote 2 months ago null point
Is this build in Arduino?
Would a programmer with no experience in robotics or electronics be able to build this by following the instructions?
The Big One wrote 2 months ago null point
Hard to say when I started I had electronics experience but no robotics experience. 6 months later I had stubby. I would say that if you are patient and willing to make mistakes it would be very doable. Email me and I will help how I can. Everyone has to start somewhere and here is as good a place as any.
Cheers
As for the arduino question, no it is not done with an arsuino, but it does use the same CPU family as arduino does (the amega family)
Karl wrote 2 months ago null point
I'd love to build one - a little beefier, can be controlled via a cellphone app or PC, has a camera mounted on it. I have no idea how to do these things so that would be a nice learning experience. Do you think you'd sell them as kits? I have almost no access to the required parts - especially the PCB and the frame :/
I have some pcbs left and have been sending them to a few people. Send me an email with your address and I can let you know the cost.
The frame would be a bit harder as I cut it by hand and it takes a very long time. Someone has posted plans for a 3d printed frame which you could try out. Anyway email me and we can chat. My aemail is on my digitalcave website.
Cheers
GoatZero wrote 3 months ago null point
Hello Wyatt thanks for all the help, and for keeping updated your log and project page,
I already got most of the components already, i just have to find the xbee modules you used since i have never used radio communication modules before reason of why im a bit confused, i will get 2 for both the PS2 controller and stubby, wherever i look (mostly ebay) i find way to many versions of the xbee, and the breakout board, some are way to expensive others are not, im a bit confused about which one is it, could you point me out in the right one please?
The Big One wrote 3 months ago null point
I had some XBee Pro version 1 modules from a previous project. There are a few things to note when choosing this:
1) Make sure you get Series 1, not Series 2. They are different, and not compatible. (Series 2 may be fine, but I have no experience with it and cannot say for certain)
2) XBee Pro have a much longer range than normal XBee. Long range is probably not required for this project, so you can go with the cheaper modules unless you think you may be re-using them for other stuff.
3) I think that these ones should work fine: http://www.digikey.ca/product-detail/en/XB24-AWI-001/XB24-AWI-001-ND/935965 . However, the ones I used are: http://www.digikey.ca/product-detail/en/XBP24-AWI-001/XBP24-AWI-001-ND/935968
4) Since you don't already have any RF stuff (i.e. no legacy requirements), you could really use anything that gives you a transparent serial port and runs at 3.3v. Basically, the interface Stubby is expecting is to be able to send data over the serial port. whatever radio you pick, it only needs to transparently send data which it receives over the serial port. For instance, I am working on using Bluetooth SPP modules for this (will be controlled by the computer).
Hope this helps! Let me know...
Cheers
David S wrote 3 months ago null point
Hey - if you still have extra PCBs, I'd like to buy one from you. I'm going to try your build with 3D printed parts :)
Yep, I still have a few. Send me an email with your address and I can verify cost and provide details. My email address is in the contact section of http://stubby.digitalcave.ca.
Cheers
Wyatt, I have several questions regarding your project which im already in the process to replicate and if possible to improve in order to learn something more, Here come a bunch of newbie questions, please brace yourself for my ignorance
1.- What exactly which servos did you use?, I found this “$2” 9g servos in hobby king,
http://www.hobbyking.com/hobbyking/store/__32095__Turnigy_TG9_9g_1_7kg_0_12sec_Eco_Micro_Servo.html
Assuming I replace the top of the frame with some modified MDF roof in order to make it able to carry stuff around while it moves (Increasing the weight) would higher weight servos accomplish this?
3.- This one is just to make sure I understand how to use a Xbee, if the PS2 controller has been modified like yours , I will need another module of the Xbee placed into stubby, , module, Stubby will need another one right however since I don't have a model at hand ?
4.- I have programed PICs 18F… using a pickit2, however I wanted to ask you exactly which programmer and what software did you use in order to program the AVR pic
5.- At the component list for stubby “1x Control PCB” can be found however I find this confusing
6.- Any chance you post some pictures of the assembled and soldered PCB and the connection with the Xbee?
7.- What software did you use to make the MDF designs? i tried using Corel, Ilustrator and Autocad to open them and review them with no luck until now, they do open but all messed up
8.- I just noticed you just updated the Assembly Instructions in your project page, they are very detailed, great job Any chance we can get some high resolution pictures?
Hi there.
No worries about questions... 3 months ago I was in exactly the same place! :-)
1) Those are the servos which I used. (The price has gone up a bit... when I bought them, they actually were $2, not $2.25. The blue version, http://www.hobbyking.com/hobbyking/store/__9549__Turnigy_TG9e_9g_1_5kg_0_10sec_Eco_Micro_Servo_.html , is a bit cheaper and I would assume that it works too, but I can't say for sure.)
2) If you wanted it to carry anything substantial (anything more than 25g or so - it is already borderline as far as weight is concerned), I would definitely want to use larger servos. The problem with that is that larger servos will not fit in the frame I designed, so you would have to modify it. Now, this is not very hard, but would involve using a CAD program (I used QCad and can highly recommend it), and that may have a bit of a learning curve if you have not used a CAD program in the past. More specifically, the coxa servos should be fine as they are, with the smaller servos (there is not a lot of load placed on these ones), The servos driving the femur and tibia should be larger, though.
3) Correct, you need two XBees to communicate with each other. The design really only calls for some sort of serial communication, though, so you could use any module that provides serial communication at 3.3v. I am planning on putting one of those cheap serial Bluetooth modules on Stubby sometime (in which case you would control it with the computer). Other options could include various eBay serial modules, or even just a cable for testing. You would probably have to tweak the software a bit, as right now it is relying on the protocol from my Universal Controller, but that is not a big deal.
4) I am using LadyAda's USBTinyISP programmer (http://www.adafruit.com/products/46). The software is AVR-GCC (compiler) and AVRDude (to upload programs). I have no idea how to get this installed in Windows, but on Debian it is easy (install avr-libc and avrdude) and on Mac I just use Crosspack (http://www.obdev.at/products/crosspack/index.html). I know you can do it on Windows, I just don't know how. To compile everything, clone the git repo, go to projects/stubby/source and type 'make'. To install, 'make install'. To set the fuses on the AVR, 'make fuse'. You can verify that you have everything installed properly before buying a single item, by trying 'make program'. It will fail to upload, of course, but the error should be from avrdude saying the programmer is not found, rather than from the OS saying avrdude is not found.
5) The control board is a PCB which I have designed and ordered from DirtyPCBs.com (the design looks like http://static.projects.hackaday.com/images/4964341397760277202.png). I have a few extra which I can send via letter mail for $5 if you are in the USA ($4 for Canada, a bit more for international depending on the country in question). This board uses a lot of surface mount resistors and capacitors, but is solderable using a normal soldering iron as long as you have steady hands. Look for Youtube videos on how to solder 0603 SMD components by hand. Alternatively, you can wire up everything by hand using a protoboard and through hole components according to the schematics (this is what I used at first, while still designing the circuit). The schematic is at http://stubby.digitalcave.ca/stubby/schematics.jsp.
6) Pictures are at http://stubby.digitalcave.ca/stubby/assembly.jsp
7) I used QCad for the frame design. I don't have access to any of those other programs, so have no idea how compatible they are.
8) Which pictures do you want higher resolution versions of? I kept them small to conserve bandwidth on my site (and since most of those pictures don't really need great detail, as they are just showing how things attach together), but I could link to some higher resolution ones if needed. Just let me know...
Hope this helps; please feel free to ask if you have other questions.
Cheers
APBurner wrote 3 months ago null point
I am new at ordering boards. Which file do I send to the board service.
Look at http://git.digitalcave.ca/gitweb/?p=projects.git;a=history;f=projects/stubby/kicad/gerber/stubby.zip;h=85ca159d7bad2bafbfc147f382d2850806c3176f;hb=HEAD . The file itself is stubby/kicad/gerber/stubby.zip. The one which I ordered is the older one (last updated 2014-05-21). I have since updated the design to include some fat capacitors on the bottom to help filter the large voltage drain that running 18 servos at the same time will do.
(Strictly speaking, you only need one of the three capacitors: the one which filters between GND and 3v3. If you don't have this one, the AVR will brown out when all the servos are moving at the same time. However, you could use the original design and just solder a cap on the expansion port, where I have already broken out GND, 3v3, VBAT, and A0-A2: this is what I have done.) I have the caps marked as 2200uF for the two capacitors on VBAT, and 470uF for the one on 3v3, although I am probably going to use a 2200uF one for all three. Currently I have a 470uF on 3v3 and that works, but larger wouldn't really hurt for something like this.
As to which one you should choose, that is really up to you. The original one is guaranteed to be correct, since it is the one which I had ordered. The new one should be fine, and has the advantage of some more capacitor holes, but I have not tried it myself.
Regardless of which one you choose, I would recommend uploading to a gerber viewing site (I use http://www.gerber-viewer.com/) and verify that things look right. (Look for things like holes not matching the solder mask, etc).
Finally, depending on where you are located, it may be easier / cheaper / faster for me to send you one of my boards. (You get 10 per order, and I only needed a couple). This would probably cost about $4 or $5 for one board, depending on exactly where you are located. Email me if you are interested. (Offer open to anyone pending interest and availability... first come, first served).
Cheers
So I have started cutting out the pieces for Stubby and find the cutting very easy. The plan is well thought out. I have found something that will make it easier on those that try this. Before you cut the leg pieces off the board cut the holes for the servos. Then you have something to hold onto and can control the cutting better, Don't ask me how I know LOL. I am cutting it out of 1/4 inch Baltic Birch plywood, Only because I am a scroller two and have a bunch already on hand.
That's a great idea... I cut them out after, and my hand was very close to the blade... it was a bit scary for some parts ;-)
Cheers
brian kame wrote 3 months ago null point
I love it!
This is really amazing, just to see how much has this evolved from V1 to the current V3, i cant wait to see V3 with 2.0 legs
I noticed you wrote in your digital cave that you sent your PCB design to china and got it made there, I was wondering if there was a way for you to share where did you sent it, I would love to attempt to send my future PCB designs the same way and get them delivered if possible
Also, this is the 1st time I hear about using painters tape on MDF in order to cut it, I tried googling to find a technique that describes what you tried to explain with “cover your MDF with painters tape and glue the design to the tape” however I didnt really understood that step, i found lots of painters using it to make messy art tho
also, just curious, around how much time do the 4 AA batteries last in stubby??
Thanks!
I used http://dirtypcbs.com/ to print this board (it was featured on HackaDay a few months back). In the past, I have also used seeedstudio's Fusion PCB (very similar). I can highly recommend both services. About 7 years ago I also got a larger PCB printed by working directly with a fab house (this was before hobby boards were really a thing); I would not recommend doing that, as it cost *way* more (IIRC it was around $100 for tooling costs alone).
Covering the wood with painters tape (or similar) is a fairly common approach when using a scroll saw. The idea is that you cover the wood with tape, and then glue the plans to the tape. You can then easily cut along the lines exactly as they appeared on the computer. When you are done, the tape removes easily without any residue. I have seen some people recommend covering the plans with a layer of packing tape as well, but I have not tried that. (I am quite new at using a scroll saw, so am not the best to ask about this... I am sure that if you ask in a scroll sawing forum, or possibly even ask APBurner (commented above), they could give you great info.
4x fully charged AA batteries lasted abour 30 - 45 minutes of continuous use in Stubby v2. I have not run Stubby v3 straight for that long, but given the fact that a) there are more servos and b) those servos are doing more work (version 2 was supported mostly by the joints; version 3 puts more load on the servos), I would guess that the batteries will last about half as long... I would be surprised if they last more than 30 minutes.
I have a battery monitor on this version, consisting of a voltage divider feeding an ADC channel. It is very interesting to see how much the voltage drops whenever Stubby moves. It may have actually been a good idea to use 5 batteries, but I didn't have the space or the battery holder to do this.
Cheers
x3n0x wrote 3 months ago null point
Sweet! excellent work! I want to scale it up about 2-3x. You wouldn't happen to have an SVG or DXF of the parts would you? That would make it easy to scale up! Coupled with a different building material and some nice beefy servos, it would be a fearsome beast at the local RC gatherings...
Yep, I do have a .dxf - look in my git repo (now with 42% more Web Interface!) at http://git.digitalcave.ca/gitweb/?p=projects.git;a=tree, and browse to projects/stubby/frame/frame_3dof_radial.dxf. I used QCad to design it, and have not used any other design programs so I can't say how compatible it is with Autocad, etc, but I would imagine it Just Works...
If you do end up building a larger version, please drop me an email... I would love to see an all-grown-up version of Stubby! ;-)
Cheers
Joshua wrote 3 months ago null point
Good work, looks very well thought out. I like the name too, fits the cheerful whirring, buzzing and clacking along. I like the idea of unloading the servos as much as possible, simply design something well and use some proper mechanics rather than just going the easy way and bolting to the servo arms.
One thing I noticed was that sometimes the servo arms in the lower leg look like they get pretty close to the ground, just thought with some roll and translate positions they might catch stuff. Also have you tried rubber feet or does the slight degree of play in footing help to keep things unloaded?
I want to make a hexapod too. At the very least I will be repurposing some of my old PS1 and 2 controllers as you have. Thanks!
Thanks!
The servo arms have not caught on anything yet, although they may if you walk in deep shag carpet or something.
Somewhat on that note, in general, I *am* pretty limited in what I can do with the Z axis. I cap the Z offsets at +/- 15mm in software; the hardware can do a little bit more, but not much (maybe 17mm if I am lucky). The limitation here is the servos: they are so small and weak that I needed to use push rods and trade mobility for torque in order to even get the thing to stand. If you have stronger servos, you could move the push rod connection point closer to the joint, which would allow for more movement distance for a given servo rotation; that would in turn allow for more height. The same torque limitation is what constrains the length of the legs: make the leg too long, and the servo is fighting against a lot more leverage.
I have considered rubber feet, and I may end up adding them, but this works pretty well already. It is much quieter in real life than it seems in the video (the problem is that the camera's microphone faces forward, and I was behind the camera when talking, so my voice is quiet and the footsteps are loud). The slight slippage does tend to help prevent overloading the servos (although that being said, Stubby works fine on carpet as well, and there is no slipping there).
I do notice that the roll math seems a bit off... for instance there is one point in the video where a leg is lifted right off the ground when demonstrating the roll. I should probably re-work that section (I am currently cheating and just doing two rotations on the XZ and YZ axis, rather than doing a single rotation on an arbitrary axis. My linear algebra is a bit too rusty to figure that out... I guess it has been too long since I was in University!)
Cheers
Frankstripod wrote 5 months ago null point
Thank you for the push rod soldering video and pictures :)
The Big One wrote 5 months ago null point
No problem, hope they are helpful!
Cheers
Mike Szczys wrote 5 months ago null point
Remarkable fabrication!
Thank you! Version 3 is coming along nicely, and is even more intricate than version 2 was... I am really wishing I had a CNC at this point! ;-)
I can understand how a CNC would help out a lot. But to tell you the truth, as your first CNC project i might take just as long as doing it by hand.
All my robot projects have been wheel-based. Seeing this I'm super tempted to try my hand at a hex build.
jfw wrote 5 months ago null point
This looks great, I'd love to use this for inspiration.
The bolts-as-bearings look pretty chunky -- how come it wasn't them bearing the weight in V1, instead of the weight being transmitted to the servos?
Version 1 didn't have the bolts / axels at all... the legs were directly connected to the servos. (This seems to be standard for most simple hexapod designs, just because it is stupid easy to assemble and program - see for instance the Sparkfun kit at http://letsmakerobots.com/node/34852).
You can see a picture of the old version at http://static.projects.hackaday.com/images/4646641397746524433.jpg
The new version is more than twice as heavy as the old one (almost 1kg, vs 400g previously), but essentially none of the weight is being borne by the servos, so it actually works out much better. The only downside is when walking on thick carpet: since it is heavier, it tends to sink in more, which means that the tips of the legs can sometime get caught when trying to lift up. Walking slowly can mitigate this, but even then I am more comfortable walking on smooth surfaces.
I currently have some el-cheapo ball bearing units on order from eBay; I am mulling over the possibility of changing the leg design yet again, to get rid of the bolts and use a real bearing assembly, plus add another joint for the third degree of freedom. Even if I choose to do this, these changes won't be for another month or so, though.
Cheers
Eric Evenchick wrote 6 months ago null point
Neat to see a homemade hexapod build with the goal of being affordable, as opposed to the many that use off the shelf kits.
The Big One wrote 6 months ago null point
Thanks! It has been very fun so far... I find the designing / making of a given project to be the fun part; to me, buying an off-the-shelf robot kit would only serve to rob me of the hours of pleasure I would otherwise get.
Once I finalize all of the build details I will be writing up instructions + BOM. I anticipate a total build cost of somewhere in the neighbourhood of $150 - $200, assuming you need to buy everything. I have been lucky to have much of what I need already (most of the electronics, wood for the chassis, etc); all I really needed to buy so far was servos (less than $50 inc. shipping), the aluminum for the v2.0 legs, and some hardware for the v2.0 joints. Assuming the design does not need to change much from where it stands now, I don't foresee the need for much else.
Stay tuned for more details!
Cheers
