Here the outline for the SDRAM is barely visible, the chip is on the underside of the board.
SDRAM | |
Pin | Name |
PIN_M7 | DRAM_BA[0] |
PIN_M6 | DRAM_BA[1] |
PIN_R6 | DRAM_DQM[0] |
PIN_T5 | DRAM_DQM[1] |
PIN_L2 | DRAM_RAS_N |
PIN_L1 | DRAM_CAS_N |
PIN_L7 | DRAM_CKE |
PIN_R4 | DRAM_CLK |
PIN_C2 | DRAM_WE_N |
PIN_P6 | DRAM_CS_N |
PIN_G2 | DRAM_DQ[0] |
PIN_G1 | DRAM_DQ[1] |
PIN_L8 | DRAM_DQ[2] |
PIN_K5 | DRAM_DQ[3] |
PIN_K2 | DRAM_DQ[4] |
PIN_J2 | DRAM_DQ[5] |
PIN_J1 | DRAM_DQ[6] |
PIN_R7 | DRAM_DQ[7] |
PIN_T4 | DRAM_DQ[8] |
PIN_T2 | DRAM_DQ[9] |
PIN_T3 | DRAM_DQ[10] |
PIN_R3 | DRAM_DQ[11] |
PIN_R5 | DRAM_DQ[12] |
PIN_P3 | DRAM_DQ[13] |
PIN_N3 | DRAM_DQ[14] |
PIN_K1 | DRAM_DQ[15] |
PIN_P2 | DRAM_ADDR[0] |
PIN_N5 | DRAM_ADDR[1] |
PIN_N6 | DRAM_ADDR[2] |
PIN_M8 | DRAM_ADDR[3] |
PIN_P8 | DRAM_ADDR[4] |
PIN_T7 | DRAM_ADDR[5] |
PIN_N8 | DRAM_ADDR[6] |
PIN_T6 | DRAM_ADDR[7] |
PIN_R1 | DRAM_ADDR[8] |
PIN_P1 | DRAM_ADDR[9] |
PIN_N2 | DRAM_ADDR[10] |
PIN_N1 | DRAM_ADDR[11] |
PIN_L4 | DRAM_ADDR[12] |
