View all 7 components
have you tried to make laser with uranium glass?However that could have made you cancer.
Thanks for the reply, I got some 385 and some 400nm from digikey, the 400nm were cheaper and work better
Very nice!
What wavelength LEDs did you use?
Sorry, a friend had those LEDs just lying around so I don't have any info on that. You can clearly see them emitting visible light... if that helps. Not sure if the marble reacts to one specific wavelength..
geragoma0
DanielZapataToledano
TAIBHSE DESIGNS
Simon Betts
Yes, delete it Cancel
You are about to report the project "Uranium Marble Ring Oscillator", please tell us the reason.
