RGB 5050 24v strips arrived.
A project log for Wide-Gamut monitor with 5050 RGB LED mod.
Increase the Color Gamut, Primary color purity and make stunning vivid and accurate LCD monitor with RGB LEDs. Inspired from Dolby PRM-4220.
thomas-chanon-wangtriratThomas Chanon Wangtrirat 10/31/2015 at 06:150 Comments
I have assembled another 2408WFP backlight unit with 10m+ of 5050 RGB LEDs. Very dense array.
Total LEDs : 1026 LED
Used checkerboard pattern and vertical layout to spread the light from LED chip even more to improve Uniformity.
24v will use less current than 12v. So, less energy wasted in copper conductor underneath pcb.
Stay tunes.
