v01 sketch
A project log for GimbalBot
Gimbaled thrusters, aerospace-grade adhesives, carbon-fiber-reinforced polymers, and inertial measurement units. This is a space project!
zakqwyzakqwy 05/02/2014 at 04:082 Comments
I started thinking back to my brief but thoroughly enjoyable experience with Kerbal Space Program and remembered a tip from the wiki: the thrust vector should be in line with the center of mass. In my mind, that means a gimbaled fan needs to be designed to apply force directly to a point along the center axis of the structure. Their site has a better (albeit brief) explanation here: http://wiki.kerbalspaceprogram.com/wiki/Center_of_thrust
So how does that happen? I putzed about a bit this evening and put together some rough sketches. Nothing based on real-world dimensions, but I tried to keep assembly constraints correct so that I can rotate the thruster about to check interferences and so forth:
Zoomed out version lying on its side (remember, the arrow points up!):
We'll call this design GimbleBot_v01. A few notes:
Nothing finalized about this, even for v01; I've just found it's easier to visualize stuff on a computer screen, and 3D modeling assembly constraints make it easy to drag rotating bits around to see how they look. Feedback?
frankstripod wrote 05/02/2014 at 05:24 point
I don't think I'm qualified to even give feedback here, but I like your project and will continue to follow this. Love the link (brief, but to the point) and its link to "Pendulum rocket fallacy" article. Your project makes more sense to me now. I would like to know what size you are thinking this will be.
zakqwy wrote 05/02/2014 at 12:55 point
I based the CAD model around one of the few commercial contra-rotating RC setups I could find (which, as I mention above, I probably won't end up using after all). The prop diameter on that unit (it's the Hobby King BL 375W system) looks to be around 200mm or so, so the CAD model is something like 3 feet from nose to tail. Using independent props on two motors as I showed above lets me mount the props as close to the center of the motor mount disk as possible, so I'll likely scale that down quite a bit. I need to do some extremely rough ballpark math on thrust and overall frame weight, and estimate the weight of the other stuff (electronics, actuators, etc); those will likely drive the scale of the first prototype.
Thanks for the comment! Everyone is qualified to give feedback.
