360° intake segment
a day ago • 0 commentsWith the PrintAirPipe - 360° Intake Segment, it is possible to direct the air inside the PrintAirPipe pipe system to the outside or to draw air from the outside into the inside of the pipe system.
The ventilation openings in the segment can be closed or opened either manually using a small lever or automatically.
The firmware of the control electronics is based on ESPHome and can therefore be integrated into many SmartHome systems such as HomeAssistant.
The STL files are available at: https://nerdiy.de/en/product-2/printairpipe-360-intake-segment-3d-printable-stl-files/
AirFlowSensor segment - Measure air speed in the pipe system
05/14/2024 at 19:29 • 0 commentsIt could be useful to measure the air speed in the #PrintAirPipe system. That's why I designed the AirFlowSensor segment to do just that. You can find more information about this and the PrintAirPipe system at nerdiy.de/papp
Inch diameter adapter to PrintAirPipe 125
04/22/2024 at 16:53 • 0 commentsMeanwhile I finished the deisgn for the Inch-Pipe Adapters. I hope I found the right mm-conversions since it looked like that these are not precisely standardized. I will also prepare some technical drawings with the exact measurements and hope that these will be useful. :)
PrintAirPipe - AirSensor Segment
04/21/2024 at 18:27 • 0 commentsWith the AirSensor Segment you can measure different Air parameters like temperature, humidity, co2 or co values. It is based on an ESP32 and ESPHome firmware.
PrintAirPipe - Servo Valve
04/21/2024 at 17:05 • 0 commentsThe servo valve segment of the #PrintAirPipe system can be used as a controllable valve.
The valve blade is controlled by an MG90 servo. Thanks to the built-in ESP32, the servo can be controlled via WiFi or the touch sensor on the housing.
The LED shows the states open (green) and closed (red). The firmware is based on #ESPhome and the files are available on my blog nerdiy.de
STLs & ESPHome Configuration:
