Screen test
05/20/2024 at 08:42 • 0 comments -
New Sketch
05/16/2024 at 12:31 • 0 comments -
NEW LOGO :)
05/14/2024 at 09:13 • 0 comments -
Controller test
05/11/2024 at 20:17 • 0 commentsAll right!!
LOGO PROJECT
05/09/2024 at 06:29 • 0 comments -
New concept
05/08/2024 at 11:23 • 0 commentsNew concept. Two displays. One side circular an the opposite side 16:9 4"
Last test lens and choice of controller
05/06/2024 at 16:05 • 0 commentsFinally I'm going to use two 75mm lenses superimposed at a distance of a couple of cm. I am waiting to receive a remote control type that mobile phones use to connect to the Raspberry Pi via USB.
Test with the output sound
05/03/2024 at 18:06 • 0 commentsAs sound output I am going to use a USB-3.5 minijack converter connected to the Raspberry Pi3. The mini Jack installed on the unit itself causes a lot of interference. I have followed the tutorial in this video to configure the USB output before that of the card itself.
Retropie user: Pi
Psw: Raspberry
Commands: view the video
Remember reboot the pi3 after the save the file
I used to the test this product
Lens tests
05/03/2024 at 11:12 • 0 commentsI have been trying another lens with higher magnification, but the result is still outside my expectations.
Failed lens test
04/22/2024 at 08:57 • 0 commentsI bought this lens to see its effect and even though it appears in the product description x10. I have to move the lens too far away so that it covers the entire diameter. I have to try another one
