Biotop
A mask that filters pollutants from the air in a biological way.
Introduction
Chlorophytum comosum, better known as green lily or grass lily, filters up to 95 percent of pollutants such as formaldehyde, benzene, or carbon monoxide from the air, according to a NASA study. So why not use plants to improve the air before you breathe it? Since about 500 g of water is released with respiration over the course of a day, this could be used to water the plants.
The mask utilizes a 180-degree view diving mask and two 750ml plastic food storage containers as mini biotopes. Important in the design was that the diving mask is not damaged in any way, for example by mounting holes. The two biotopes are connected to the mask using a 3D-printed adapter. The two biotope containers can be removed so that you can grow different plants. The mask also features 3-D printed AR glasses and two gas sensors, one on the inside and one on the outside. The values are displayed on the AR glasses. This allows you to experiment with different plant species. Other data can also be transferred to the AR glasses via Bluetooth. The AR glasses can be removed to use for other projects. Other sensors can be connected as well since the glasses have basically two I2C ports with a 3.3V power supply each.
This project sees itself as a mixture of art and science. It is intended to draw attention to devastating environmental pollution. According to the World Health Organization, air pollution is now the world's greatest environmental health risk. However, the real goal of the project is to achieve a symbiosis of two biological systems through technology. While working on the project, I have already gained scientific knowledge, for example, that sodium alginate is suitable as a substitute for soil.
The mask can be used for a student science project or at exhibitions, fairs, and vernissages. Another application would be aromatherapy.
Breathing in and out with the mask proceeds as follows.  One-way air valves are embedded in the two lids of the plastic food storage containers which open on inhalation and close on exhalation.
AR glasses overview
In my arrangement, the lens is between the OLED and the mirror. The lens is horizontally adjustable so that you can adjust the AR glasses to the user's visual acuity.
Ideally, the microscope slide would be semi-mirrored. Fortunately, there is an appropriate foil, which is actually intended for windows to protect interiors from too much sunlight. That's real hacking, isn't it?
Power management
I am using an Arduino Nano 33 BLE for this project. It's the first time, I got my hands the first time on this evolution of the traditional Arduino Nano with a lot more powerful processor. The microcontroller is powered via the VIN pin. According to the schematic, the board uses an MPM3610 synchronous step-down converter, whose input voltage must be between 4.5 and 21 volts. So we can't power the microcontroller directly from a 3.7 V LiPo battery. Therefore we need appropriate power management. It consists of the 3.7 V LiPo battery, a switch between "charge" and "operate", a USB LiPo battery charger, and a step-up converter, which converts the 3.7V into 5V, which is then fed to the VIN pin.
I2C multiplexer
Two SGP30s are used as gas sensors. The sensor measures eCO2 (equivalent calculated carbon dioxide) concentration within a range of 400 to 60,000 ppm, and TVOC (Total Volatile Organic Compound) concentration within a range of 0 to 60,000 ppb. 400 ppm CO2 is the normal concentration in the air, and the sensor uses this value as a baseline. The disadvantage of this sensor is that it has a fixed I2C address (0x58) which cannot be changed. The problem can be solved with appropriate software, but I decided to use a hardware I2C multiplexer. Here the TCA9543A Low Voltage 2-Channel I2C Bus Switch from Texas Instruments is a good choice.
Agar instead of soil
As you move with the mask and bend forward, for example, simple plant soil is not the best choice, because...
x-zip-compressed - 69.54 kB - 05/22/2023 at 14:03
Download
Standard Tesselated Geometry - 826.25 kB - 05/16/2023 at 11:08
Download
Standard Tesselated Geometry - 207.50 kB - 05/16/2023 at 11:08
Download
Standard Tesselated Geometry - 70.49 kB - 05/16/2023 at 11:08
Download
Standard Tesselated Geometry - 15.32 kB - 05/16/2023 at 11:08
Download
View all 16 files
  • 1 × Arduino Nano 33 BLE
  • 2 × Adafruit SGP30 TVOC/eCO2 Gas Sensor breakout
  • 1 × Mini Boost Step Up Converter Board Module 3,7V to 5V, 8V, 9V or 12V Amazon/Ebay
  • 1 × TP4056 USB LiPo battery charger breakout Amazon/Ebay
  • 1 × LiPo battery 3.7V/250mAh, with PCM Amazon/Ebay
View all 12 components
  • How to propagate green lily
    M. Bindhammer05/02/2023 at 14:35 0 comments
    Hardly any houseplant is as easy to propagate as the green lily. In each growth phase, it forms many offshoots that appear after flowering on the long flower shoots. These offshoots bend downwards so that the "offspring" in nature eventually come into contact with the soil and take root there. This behavior makes it very easy to pull new green lilies from the offshoots:
    • Using a sharp knife cut the offshoots from the flowering shoot as soon as they have five leaves of their own.
    • If the offshoots have already formed roots, they can be planted directly, even two or three together in a pot, which will make a more lush plant.
    • If the offshoots have not yet formed roots, place them in a glass jar and wait until they have formed enough roots, then pot them up.
    • Do not forget to water after planting!
    Image source: plantopedia
    After a few weeks, one of the green lilies I bought finally started to sprout plantlets.
    Another week later...
    After the offshoots had at least five leaves of their own, I cut the offshoots off the flower sprout with a sharp knife and watered them to get roots.
    Another two weeks later, the offshoots finally got roots so I could transfer them into the plastic containers.
  • Code
    M. Bindhammer04/28/2023 at 12:24 0 comments
    The following code displays the gas sensor values on the AR glasses.
      Note: Because the sensor is warming up,
      the first 10-20 readings will always be
      TVOC 0 ppb and eCO2 400 ppm.
    #include <Arduino.h>
    #include <U8x8lib.h>
    #include <Wire.h>
    #include "Adafruit_SGP30.h"
    Adafruit_SGP30 sgp1; // Define two classes
    Adafruit_SGP30 sgp2;
    U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE);
    void setup(void)
      Serial.begin(9600);
      u8x8.begin();
      u8x8.setPowerSave(0);
      // Start I2C communication with the multiplexer
      Wire.begin();
      // Init sensor on bus number 0
      TCA9548A(0);
      sgp1.begin();
      // Init sensor on bus number 7
      TCA9548A(7);
      sgp2.begin();
    void loop(void)
      printValues(sgp1, 0);
      printValues(sgp2, 7);
    // Function to select I2C BUS
    void TCA9548A(uint8_t bus)
      Wire.beginTransmission(0x70);  // TCA9548A address
      Wire.write(1 << bus);          // Send byte to select bus number
      Wire.endTransmission();
    // Function to display sensor values on the OLED
    void printValues(Adafruit_SGP30 sgp, int bus)
      u8x8.setFont(u8x8_font_7x14B_1x2_r);
      TCA9548A (bus);
      Serial.println(bus);
      if(bus == 0) u8x8.drawString(2,10,"Inside: ");
      else u8x8.drawString(2,10,"Outside:");
      u8x8.drawString(2,20,"TVOC:");
      sgp.IAQmeasure();
      u8x8.setCursor(2,30);
      u8x8.print(sgp.TVOC);
      u8x8.print(" ppb");
      delay(3000);
      u8x8.drawString(2,20,"eCO2:");
      u8x8.print(sgp.eCO2);
      u8x8.print(" ppm");
      delay(3000);
  • Building the mask
    M. Bindhammer04/26/2023 at 14:56 0 comments
    The parts for the mask adapter have also been selective-laser-sintered in PA 12 but kept white.
    I placed valves in the lids of both containers, as described in my Log Air valves. Using a drilling template I made, I drilled the necessary holes in the containers. For the large hole, I used a step drill. The drill holes must be made at low speed, otherwise, the plastic will melt.
    The two Adafruit SGP30 breakout boards need to have pin headers soldered into them, one straight and the other angled. Furthermore, we need two four-pin JST connectors 2.54 PH with 30 cm cable.
    One wire harness was fed through the hole in the 3-D printed tee and the wires were soldered to the Adafruit SGP30 breakout board with the straight pin headers and heat shrink tubed. I did the same with the second harness and the Adafruit SGP30 breakout board with the angled pin headers.
    The SGP30 breakout boards were then screwed to the cover of the tee. For that, I used four stainless steel M2 x 16 mm and nuts. The four nuts were each secured with a drop of super glue. We don't want these to become loose and possibly get into our respiratory tract.
    The lid was then glued into the opening of the tee with sanitary silicone. The cable gland was also sealed with silicone. Since the silicone needs 24 hours to cure, the lid was fixed with tape.
    After the silicone had cured, I wrapped the two cable harnesses with spiral tubing. This looks nicer and prevents the cables from getting tangled.
    For safety reasons, I decided to install a fly screen between the inner and outer flanges. This way, nothing can accidentally get into the respiratory tract. You can also experiment with other filter materials. I punched discs out of the fly screen with a 30 mm diameter hole punch.
    The two flanges were then bolted to the container using four M2 x 14mm stainless steel bolts and nuts each. If your hand does not fit in the opening, you can help yourself out with needle-nose pliers.
    Next, I inserted the tee into the snorkel opening of the mask and then the two containers with the prepared flanges.
    The last part that is needed is the AR glasses bracket. This part was also laser-sintered from PA 12 powder and then dyed black.
    The holder is designed to be snap-fit inserted into the mask without using screws or glue, so the mask gets not damaged.
    Since the microscope slide interfered with the nose section of the mask, I shortened it. This can easily be done with a glass cutter.
    The bracket was then bolted to the AR glasses using 2 stainless steel screws 3 x 12 mm and nuts.
    Front and side view of the finished mask:
  • Building the AR glasses​
    M. Bindhammer04/25/2023 at 12:39 0 comments
    The parts for the glasses have been selective-laser-sintered in PA 12 and then dyed black.
    I had to trim the slots of the lens holder a bit with a cutter knife.
    Then I glued the lens in place with 2-component epoxy glue.
    I also glued the mirror into the housing with 2-component epoxy glue. A recess is provided so that it can be positioned more easily.
    Next, I covered a microscope slide with semi-mirrored foil. Care must be taken so that no bubbles form. Then I inserted the slide into the appropriate 3-D printed holder and secured it with two drops of super glue.
    Using an M2 x 35mm bolt and nut, I then attached the microscope slide to the housing. The mirror foil should be on the side facing the eye. It should be not too easy to pivot the microscope slide. The M2 nut was finally secured with a drop of super glue.
    After that, I started working on electronics. First I desoldered the two resistors next to the letters "A" and "B" on the Boost Step-Up Converter Board Module. This is necessary to set the output voltage to 5V.
    The TP4056-based LiPo charger must also be modified to reduce the charging current. Details can be found in my log TP4056-based LiPo charger modification.
    The wiring was then done as follows:
    I insulated the LiPo charger and the step-up converter with heat shrink tubing to avoid accidental contact. Before installation, the electronics were tested.
    The Arduino Nano 33 BLE was attached with four self-tapping M1.5 x 6mm screws, the OLED, and the custom PCB with six M2 x 8mm screws, 3mm spacers, and the corresponding nuts.
    The biconvex lens should be about 10mm in front of the OLED, the more convex side towards the OLED. The closer the lens is to the OLED, the smaller the image projected onto the microscope slide will be. Now the protective film can also be removed from the OLED.
    Finally, the AR glasses were screwed together with four M1.7 x 8mm screws and the sliding knob for the lens was inserted.
    The glasses from the first-person viewpoint:
  • Custom PCB
    M. Bindhammer04/06/2023 at 10:38 0 comments
    One custom board is needed for the project on which the I2C multiplexer, the connectors for the LiPo battery, the gas sensors, the IC2 bus, and the on/off switch are located. The PCB will be mounted in the AR glasses housing.
    PCB and stencil for the top layer:
    Populated PCB:
    To check the function, I wrote a small test program for the Arduino Nano 33 BLE:
    #include <Adafruit_SGP30.h>
    #include <Wire.h>
    void TCA9548A(uint8_t bus){
    // Function to print the sensor values
    void printValues(Adafruit_SGP30 sgp, int bus) {
      TCA9548A (bus);
      Serial.print("Sensor number on bus");
      sgp.IAQmeasure();
      Serial.print("TVOC "); Serial.print(sgp.TVOC); Serial.print(" ppb\t");
      Serial.print("eCO2 "); Serial.print(sgp.eCO2); Serial.println(" ppm");
      Serial.println();
    void setup() {
      Serial.begin(115200);
      // Start I2C communication with the Multiplexer
      Wire.begin();
      TCA9548A(0);
      sgp1.begin();
      TCA9548A(7);
      sgp2.begin();
    void loop() {
      // Print values for sensor 1
      Serial.println("Sensor 1:");
      delay(1000);
      // Print values for sensor 2
      Serial.println("Sensor 2:");
      delay(1000);
  • Agar instead of soil?
    M. Bindhammer04/04/2023 at 08:26 0 comments
    For the first experiment, 4g of agar was boiled in 100 ml of distilled water, and 2 ml of universal liquid fertilizer was stirred in. After cooling, some dill seeds were placed on the agar surface and watered.
    I then used a toothpick to make holes in the agar and pushed the seeds into the holes.
    After a few days, the first mold cultures formed on the agar. I had not thought that this would happen so quickly. Some molds seem to be quite undemanding. I will let the experiment continue, as I am primarily interested in whether the seeds sprout and grow in the medium.
    Another possibility would be sodium alginate, which gels when it comes into contact with calcium lactate and finds use primarily in so-called molar cuisine. Or simply a layer of soil, on top of it a layer of expanded clay pebbles, and finally a kind of retainer that retains the pebbles but is permeable to water and air.
    Since I am very interested in the theme, I started another series of experiments. The Petri dish on the left contains agar, and the one on the right contains sodium alginate, which I have set with concentrated calcium lactate solution. This time I use cress seeds (Lepidium satlyum) because they sprout much faster.
    A few days later, the cress seeds sprouted. It seems that the cress grows faster on the sodium alginate substrate than on agar. I suspect it is because the roots penetrate the sodium alginate more easily than the agar. Both Petri dishes can be turned upside down and the plants adhere very well to the substrate.
    A few days later it is even more obvious:
  • Air valves
    M. Bindhammer04/03/2023 at 10:53 0 comments
    Air valves must be fitted in the two closing lids of the mini-biotopes, which allow inhalation via the biotopes but prevent exhalation. Exhalation takes place via corresponding valves integrated into the diving mask. I use a valve that can be found in some FFP2 masks for this purpose.
    I drew stencils in Inkscape and applied them to the lids using spray adhesive. Then the cutouts were sawed out with the scroll saw, sanded, and cleaned with isopropanol before the air valves were glued in place with 2-component epoxy glue.
  • TP4056-based LiPo charger modification
    M. Bindhammer04/03/2023 at 09:10 0 comments
    I use a TP4056-based LiPo charger with a micro USB connector. The charging current is 1A according to the manufacturer. But since I use a 250mAh LiPo battery, I need a lower charging current (max. 250mA). The following excerpt from the datasheet shows that the resistor at pin 2 of the TP4056 determines the charging current. So I have to change the resistor accordingly.
    The charging current can be accurately calculated by the following formula:
    The according resistor is located in the middle of the lower side of the PCB and is labeled with "122":
    Testing the charger after modification:
    The LiPo battery I use has the following characteristics:
    The first DC-DC step-up converter I tested was total garbage. Even with a constant input voltage, the output voltage fluctuated consistently over 1 to 2V. The following one is fine. The output voltage can be programmed via two solder jumpers.
  • Arduino Nano 33 BLE
    M. Bindhammer04/02/2023 at 14:04 0 comments
    IMU
    The nice thing about the Arduino Nano 33 BLE, besides the Bluetooth, is that it has an IMU on board. We can use it as a human-machine interface for the AR glasses. To do this, the Arduino_LSM9DS1 library needs to be installed. An example code for the accelerometer is shown here. The accelerometer can also be used to go into power save mode when no movement is detected for a certain time, for example during charging. In addition, a warning can be issued if one takes critical positions while wearing the mask.
    U8x8 lib
    The U8x8 library works without problems with the Arduino Nano 33 BLE. An unnamed I2C 128x64 OLED was used for testing.
    Adafruit SGP30 lib
    Also the Adafruit SGP30 library works without any issues with the Arduino Nano 33 BLE.
  • Started to design the AR glasses
    M. Bindhammer04/01/2023 at 08:32 0 comments
View all 10 project logs
View all instructions
M. Bindhammer wrote 07/07/2023 at 20:36 point
@ Bn0rmal Sure I will post results.
Bn0rmal wrote 07/07/2023 at 15:00 point
does this work well enough for it to be feasible? or practical?
M. Bindhammer wrote 07/07/2023 at 15:49 point
The filtering works well. If it is practical, I don't know. The benefits are often only recognized later.
Bn0rmal wrote 07/07/2023 at 18:31 point
will you be testing the device and posting the results? im curious to see.
Kris Keillor wrote 05/11/2023 at 17:07 point
Well come on, we need a photo with the plants in!
M. Bindhammer wrote 05/11/2023 at 17:40 point
I need to wait till my green lily gets plantlets.
