This article shows a transistor audio filter.
The filter is made from three Darlington pair transistor voltage followers.
Step 1: Design the Circuit
Connecting two of more capacitors in parallel reduces the current dissipation across each capacitor.
Calculate transistor input resistance Beta*re:
Beta*reB = Beta * (26*10^-3) / Ie
= Beta * (26*10^-3) / (Vs / 2 / Re1)
= 100 * (26*10^-3) / (1.5 V / 2 / 10,000 ohms)
= 17,333.3333333 ohms
Beta*reA = Beta * (26*10^-3) / (Ie / Beta)
= Beta * (26*10^-3) / (Vs / 2 / Re1 / (Beta + 1))
= 100 * (26*10^-3) / (1.5 V / 2 / 10,000 ohms / 101)
= 1,750,666.66667 ohms
= 1.75 Megohms
Calculate input resistance of the Darlington pair transistor voltage follower:
(We are ignoring the transistor input resistance Beta*re)
Ri = (Beta + 1)*(Beta + 1) * Re = 101 * 101 * 10,000 ohms
= 102,010,000 ohms = 102.01 Megohms
The transistor input resistance Beta*re will only add to the total voltage follower input resistance.
Calculate output resistance of the Darlington pair transistor voltage follower:
(We are ignoring the transistor resistance Beta*re)
Ro = Re || ((Rb1a || Rb2b) / (Beta + 1) / (Beta + 1))
= 10,000 ohms || (((1*10^6 ohms)||(10*10^6 ohms)) / 101 / 101)
= 88.3306392488 ohms
The transistor input resistance Beta*re will increase the output resistance slightly.
Calculate minimum low pass filter frequency:
FlpfMin = 1 / (2*pi*(Rlp1 + Rlp2)*(Clp1 + Clp2))
= 1 / (2*pi*(1,010,000 ohms)*(2*10^-9))
= 78.7895757881 Hz
Calculate maximum low pass filter frequency:
FlpfMax = 1 / (2*pi*Rlp1*(Clp1 + Clp2))
= 1 / (2*pi*(10,000 ohms)*(2*10^-9))
= 7,957.74715459 Hz
Calculate minimum high pass filter frequency:
FhpfMin = 1 / (2*pi*(Rhp1 + Rhp2)*Chp)
= 1 / (2*pi*1,001,000 ohms*(47*10^-9))
= 3.38289249244 Hz
Calculate maximum high pass filter frequency:
FhpfMax = 1 / (2*pi*Rhp1*Chp)
= 1 / (2*pi*1,000 ohms*(47*10^-9))
= 3,386.27538493 Hz
Step 2: Simulations
Transient 1:
Transient 2:
Full Spectrum Bandwidth:
Spectrum Low Pass Filter (LPF):
Spectrum High Pass Filter (HPF):
