A small, simple, low-cost, versatile PCB that can be used to make filters, attenuators, amps, dummy-loads the DIY-way
For the second use case I wanted to try design a 30dB DIY-Attenuator. I used this attenuator calculator (german) to calculator the resistors for a PI-configuration at 50 Ohm input and output impedance. I needed to place 53.3 Ohm and 789.8 Ohm resistors – in order to generate the right resistor values – I choose to put for each resistors, two resistors in parallel. The needed values I calculated with the tool pointless-resistance, which automatically searches the values of the E-Series for suitable candidates within a defined tolerance.
for 789.8 Ohms – I used 820 parallel with 22k – which results in 790.5 Ohms
for 53.3 Ohms – I used 56 parallel with 1k2 – which results in 53.5 Ohms
In the Simulation you can see that major share of the power has to be dissipated by the lower resistor close to the input. The 0603 Resistors I am using have a power rating of 100mW which is the limiting factor. 100mW translates to 20dBm which is enough for my experiments. (see Watt-dBm converter) – But a more clever solution would be to use different resistors in physical size, because in our schematic only R2 has to dissipate the majority of excess power. For example a 1218 Resistor would be sufficient enough for 1Watt / 30dBm. (See resistor sizes and power dissipation)
After the math it is time for solder – and the result looks like this:
And to measure its performance lets connect it again to the VNA:
Measurement results in the Range 1-500 Mhz:
We are pretty close to our 50 Ohm impedance. The flatness of the attenuation ranges from -30.01 dB to -28.35 dB. The parasitic capacitance already start to show up a little.
Measurement results in the Range 1-1000 Mhz:
The parasitic capacitance are getting stronger and flatness is -30.64 to -28.53dB
I conclude that the attenuator is good enough for my “lowfi” experiments. But lets compare it to a commercial available attenuator (specified up to 3Ghz).
commercial -20dB 3Ghz Attenuator (1-500Mhz):
The impedance is just a spot (the vertical lines that are visible are only the markers). Flatness is: -19.97 dB to -18.52dB
commercial -20dB 3Ghz Attenuator (1-1000Mhz):
The impedance is still spot on – although you can see spurs which are related to the measurement. The spot is a bit broader because the accuracy of the VNA degrades a little above 500Mhz The flatness is: -19.11 dB to 21.78 dB
In this first example I would like to design a 50Ohm-Dummyload capable to dissipate 10 Watts – the resistor I have chosen for this task is a Bourns PWR263S-35-50R0F – which is specified for 35 Watts (with proper cooling). This resistor is a thick-film resistor, because we want to keep parasitics inductances low and has a tolerance of 1%.
To measure the performance I attached the DIY-Dummyload to a VNWA3E Networkanalyzer
In the frequency range from 1-500Mhz the DIY-Dummyload shows up as a dot in the Smith Diagramm. Exactly what we want.above 500Mhz the parasitic capacitance of the RF Biscuit starts to show – but depending on your application such a result might be considered still as good-enough.
Let’s compare this result to a commercial 50Ohm-Termination
The following Smith Diagramm shows the 50Ohm-Termination in the Frequencyrange of 1-1000Mhz:
In this Diagramm you can see that the dot is a bit broader – which can be explained as the VNWA3E is less accurate above 500Mhz . You can also see spurs which are releated to the measurement device and which are not part of the characteristics of the 50Ohm Termination.
I will update this part with an evaluation of the thermalperformance of the DIY-Dummyload.
I just grabbed the KiCad files...looks like this is a 2 layer board? Is there a reason you didn't do a 4 layer with impedance controlled substrate? Did you find it unnecessary?
BTW, another mention in a recent article about Baofung handys: https://hackaday.com/2016/12/14/measuring-spurious-emissions-of-cheap-handheld-transceivers/
I'm curious: the isolated center pads and several outside pads have an unconnected via. Is that just to keep them attached to the FR4?
Also, I see grounded pads for a metal shield. Is there a specific, existing part number you based that on, or would one need to fabricate them?
Really nice! Makes me want to print a few and give em' to my friends, but I don't feel like soldering all the parts. You know any in house soldering manufacturers?
nice project, totally interested in ordering up some boards, will be handy as I progress further into the RF field with my own designs, this is a great idea!
Hi George. Where can I find the kicad or gerber files for this board? Thanks.
