My battery. Is of such a design that it can charge and discharge simultaneously without any harm to the battery by compartment method.
It is in a way. If you are really interested please just contact me :-)
Actual)y the no of cycles do not increase
Such ismyconditions 😀😁
Do you have any experience with batteries ?
A battery either charges, or discharges. If the phone is used at the same time, there is no problem. Charging one cell while discharging another is a bad idea because it increases the number of cycles of charge/discharge, which is reduces its efficiency and capacity.
And so far, we have survived as a civilization with single-cell batteries :-)
How is it different from using two batteries?
