This is a simple little fashion project. Who doesn't need platform boots that light up and a skirt that responds to music? Fun for newbies.
Step one of this project was to create an LED Strip. I'm working with this skirt
The idea is to sew the leds into the gathers of the fabric. I am using neopixels for this project and an adafruit flora. As well, the project will run off a lipo battery that has 3.7V and 1200mAh of current. If you do the math for the components, you have the ability to use about 20 of the Neopixels with this setup.
The problem is that I want to also use a little sound sensor so I am working on the assumption that will need some voltage and current too. Plus, I'm bound to have some current loss because of the wires and the length of the skirt. The sound sensor is an electret Mic Amp, the MAX4466. It has a current draw of about 24-48 microamps per amp. That's great news because that's basically very small indeed! 1 microamp is .001 milliamps! It's nearly free. It'll draw some voltage too. The data sheet is here but for now, I'm going to avoid actual math and just hack at it. I'll use 17 LEDs and hope that'll work out. If I fail, multimeter & calculator time!
https://cdn-shop.adafruit.com/datasheets/MAX4465-MAX4469.pdf
First things first was to create the LED chain. I cut the wires in roughly the right lengths and got to soldering. I also sealed the solder joints with hot glue to stabilize my solder joint. I might add more glue if things break during the test run.
So far, they are working.
Now I'm just waiting for the skirt to arrive in the mail and then I'll need to add the rest of the circuit.
That's good to work on fashion category program. I need help to make the similar one for my diamond necklaces project.
This is amazing. I really like your design idea. Can you share more design similar to this for hair wigs products? I have got some artificial from this store, https://www.lacexclusive.com/virgin-hair.html
This is looking great step in fashion projects. I'm also working on the similar project of perfume reviews, you can see here https://www.bestperfumeforwomen2020.com/
It sounds like you're embarking on an intriguing project! Sewing LEDs into fabric gathers can create stunning visual effects. Neopixels and the Adafruit Flora seem like great choices for flexibility and ease of use. Your power setup with a 3.7V, 1200mAh LiPo battery should support around 20 Neopixels, which is impressive.
Integrating a sound sensor adds another layer of interactivity to your project. It's wise to consider its voltage and current requirements, especially given potential losses due to wire length and the skirt's size. The MAX4466's low current draw is definitely a plus, making it a feasible addition.
Your decision to start with 17 LEDs and adjust as needed demonstrates a practical approach. Soldering and sealing the joints with hot glue are smart moves for durability, especially considering the project's wearability.
Keep up the good work, and I look forward to seeing how your project progresses! If you need further assistance or want to share updates, feel free to visit https://eodaan.com/ , where creativity thrives.
