Gear_M1,5_Z16.stlThis gear is pressed on the axle of the potentiometer. Optionally the 16 teeth gear cut from POM can be glued on top to provide extra strong teeth.sla - 537.96 kB - 09/12/2016 at 13:19 |
gears.dxfAll the gears for the 10/25 transmission.AutoCAD DXF - 219.19 kB - 09/12/2016 at 13:17 |
Gear_M1,5_Z10.stlThis gear is placed on top of the last gear inside the gearbox of the linear actuator. The little tabs fit inside (may need some filing) the slots of the metal gear. (Gear module = 1.5mm, 10 Teeth)sla - 491.01 kB - 09/12/2016 at 13:17 |
Encoder_Base.stlThis part connects to the gearbox of the linear actuator and holds the big gear.sla - 588.03 kB - 09/12/2016 at 13:14 |
Encoder_Middle.stlThis part holds potentiometer.sla - 658.99 kB - 09/12/2016 at 13:14 |
Encoder_Cap.stlCap for the potentiometer with a hole for the cable.sla - 376.92 kB - 09/12/2016 at 13:14 |
