Generator V2_WIP.stpHeavily WIP CAD file on V2 generatorstp - 2.88 MB - 11/30/2018 at 11:32 |
Generator.pdfExploded view of generator V1Adobe Portable Document Format - 250.37 kB - 11/02/2018 at 13:25 |
Feild stopper.dwgDGW of MS Feild Stopper Generator V1DWG Drawing - 199.14 kB - 11/02/2018 at 13:25 |
Feild Stopper Drawing.pdfPDF for MS Feild Stopper Generator V1Adobe Portable Document Format - 3.20 kB - 11/02/2018 at 13:25 |
Portal Point Gen V1.rarAutodesk Inventor Pack&Go FilesRAR Archive - 20.84 MB - 10/22/2018 at 14:05 |
Generator.rarFull assembly STEP filesRAR Archive - 714.24 kB - 08/11/2018 at 06:32 |
Rotor Brace.stlPart of the rotor assemblyStandard Tesselated Geometry - 360.34 kB - 08/11/2018 at 06:19 |
Coil Holder.stlPart of the Stator AssemblyStandard Tesselated Geometry - 444.61 kB - 07/13/2018 at 10:47 |
center HUBgear.stlGear to couple with a wind turbineStandard Tesselated Geometry - 259.16 kB - 07/13/2018 at 10:47 |
coil winding jig.stlPart of the Jig used to wind coilsStandard Tesselated Geometry - 80.94 kB - 07/13/2018 at 10:47 |
outer Caseing_MIR.stlPart of the exterior casing for the generatorStandard Tesselated Geometry - 60.82 kB - 07/13/2018 at 10:47 |
outer bearing hlder.stlPart of the Outer casing assemblyStandard Tesselated Geometry - 42.95 kB - 07/13/2018 at 10:47 |
Standard Tesselated Geometry - 42.27 kB - 07/13/2018 at 10:47 |
Rotor.stlPart of the rotor assemblyStandard Tesselated Geometry - 159.46 kB - 07/13/2018 at 10:47 |
small gear.stlGear to mount on the generator output shaftStandard Tesselated Geometry - 72.74 kB - 07/13/2018 at 10:47 |
Rod Clamp.stlClamp to hold the generator to a poleStandard Tesselated Geometry - 29.96 kB - 07/13/2018 at 10:23 |
Standard Tesselated Geometry - 62.29 kB - 07/13/2018 at 10:23 |
jig holder.stlPart of the coil winding jigStandard Tesselated Geometry - 20.39 kB - 07/13/2018 at 10:23 |
outer Caseing.stlpart of the generator assemblyStandard Tesselated Geometry - 60.82 kB - 07/13/2018 at 10:23 |
Spacer.stlspacers to place between the rotors and statorStandard Tesselated Geometry - 23.32 kB - 07/13/2018 at 10:21 |
Standard Tesselated Geometry - 39.73 kB - 07/13/2018 at 10:21 |
stator cover.stlpart of the stator assemblyStandard Tesselated Geometry - 27.43 kB - 07/13/2018 at 10:21 |
