syslog-temp-sleep-mode.inoThe code for the ESP8266. You can enable/disable an OLED display and serial output by uncommenting a couple lines. You must first enter your WiFi SSID, password, and an rsyslog IP for this to work.ino - 3.63 kB - 09/24/2018 at 22:06 |
