Tailpiece-4String-R3.stlA 4-string tailpiece! Print this with lots of plastic, it needs to be strong.Standard Tesselated Geometry - 483.29 kB - 07/15/2019 at 23:13 |
PegShort-R1.stlThis may work with the Pegbox-pegs, but may also need a lot of sanding/filing. I still recommend the Grover tuners, but if you want to try pegs, give it a go.Standard Tesselated Geometry - 379.96 kB - 07/15/2019 at 23:13 |
Pegbox-4String-Grover6-R3.stlThis updated Pegbox has some minor changes.Standard Tesselated Geometry - 655.16 kB - 07/15/2019 at 23:13 |
Pegbox-4String-Pegs-R4.stlThis updated Pegbox has smaller holes for smaller pegs.Standard Tesselated Geometry - 665.80 kB - 07/15/2019 at 23:12 |
Bridge-R10.stlThe bridge is updated for the new body. Any bridge R8-R10 should work OK.Standard Tesselated Geometry - 236.31 kB - 07/15/2019 at 23:12 |
Bridge-Generative-R4.stlReduced the height of the generative bridge for better string heights.Standard Tesselated Geometry - 3.54 MB - 07/15/2019 at 23:12 |
Bout-R7.stlA new body! This body has many improvements. I have a blog post about it coming soon.Standard Tesselated Geometry - 1.26 MB - 07/15/2019 at 23:11 |
Complete Modular Fiddle Acoustic V1-R6.stlThis is a STL of the entire assembly. Use this to edit the design with mesh modeling software. Some parts are outdated!Standard Tesselated Geometry - 5.15 MB - 12/10/2018 at 23:32 |
Pegbox-4String-Pegs-R3-Oriented.stlThis is a ground up redesign of the Pegbox. This new design offers better mechanical support, easier tuning, different aesthetics, and a fun way to hang your fiddle. This Pegbox is designed to be reamed and set up with traditional violin pegs.Standard Tesselated Geometry - 646.76 kB - 12/10/2018 at 23:32 |
Neck-4String-R6-withSupport-Oriented.stlThis Neck is a ground-up redesign. I've improved Neck profile for printing, improved nut shape, and improved aesthetics. This STL includes the needed support material.Standard Tesselated Geometry - 550.47 kB - 12/10/2018 at 23:32 |
Neck-4String-R6-noSupports-Oriented.stlThis Neck is a ground-up redesign. I've improved Neck profile for printing, improved nut shape, and improved aesthetics. This STL does not include the needed support material.Standard Tesselated Geometry - 407.50 kB - 12/10/2018 at 23:32 |
Bridge-4String-R9-Oriented.stlBridge height is updated for better string heights.Standard Tesselated Geometry - 206.82 kB - 12/10/2018 at 23:31 |
Pegbox-Grover-R6-oriented.stlThis Pegbox fits Grover 88B, 6-series, or 3055 tuners. R6 is angled for better string path to nut and improved mechanical load on Pegbox. Oriented for printing.Standard Tesselated Geometry - 382.60 kB - 10/23/2018 at 21:56 |
Bridge-Generative-R3-oriented.stlThis bridge is designed using Autodesk Generative Design. It sounds very different! Try it as your first experiment. Also check the youTube videos for demonstration.Standard Tesselated Geometry - 4.27 MB - 10/15/2018 at 22:54 |
Body-R5-withSupports-oriented.stlThis is the Body with modeled supports. Oriented for printing. There is an updated Body file! See R7.Standard Tesselated Geometry - 1.41 MB - 10/15/2018 at 21:14 |
Body-R5-oriented.stlThe Body without modeled supports. Oriented for printing. There is an updated Body file! See R7.Standard Tesselated Geometry - 1.04 MB - 10/15/2018 at 21:14 |
