Mac mini (Late 2018) Cold Plate - EHP Mod.scadModified for aftermarket heat pipes with 3 pairs listed. Will update when material reduction is present to lower cost of manufacturing.scad - 4.78 kB - 01/15/2019 at 23:08 |
Mac mini (Late 2018) Cold Plate - SA Mod - Sine Wave.scadModified cold plate for thicker and louvered cold plate for greater surface area and all copper construction. Code cleanup & heat pipes added.- 5.90 kB - 01/10/2019 at 04:15 |
Mac mini (Late 2018) Cold Plate - Clearance.scadStock cold plate with EMI cage clearance added.- 2.31 kB - 01/10/2019 at 04:14 |
PwrData_2018-12-25_17-30-00 - MM i7-8700B MX-2 & Lapping.csv.bz2Lapped Heatsink & MX-2 TIM Hardware Thermals, bzip2 compressionBzip2 Archive - 23.30 MB - 12/26/2018 at 03:40 |
PwrData_2018-12-25_17-30-00 - MM i7-8700B MX-2 & Lapping.csv.xzLapped Heatsink & MX-2 TIM Hardware Thermals, xz compressionxz - 17.83 MB - 12/26/2018 at 03:40 |
PwrData_2018-12-23_19-45-00 - MM i7-8700B Stock.csv.bz2Bone Stock Hardware Thermals, bzip2 compressionBzip2 Archive - 22.83 MB - 12/26/2018 at 03:14 |
PwrData_2018-12-23_19-45-00 - MM i7-8700B Stock.csv.xzBone Stock Hardware Thermals, xz compressionxz - 17.41 MB - 12/26/2018 at 03:07 |
