LoopTune.ino
Automatic tuning program as of Oct 2019. Working.
ino - 31.95 kB - 06/15/2020 at 19:19
Download
ESP32 mounted on prototyping board with SparkFun Motor Controller. Blue circuit board of the Adafruit clock generator board. It's output connects to my 5-pole low pass filter (about 19 MHz). The output of the filter drives the coupling loop (link). The vertical SMT prototype board has a AD8307AN log amplifier to measure the sampled RF.
JPEG Image - 183.05 kB - 09/10/2019 at 15:57
Preview
The loop antenna main loop is modeled with a copper coil wound on a custom 3D printed form. The exciter loop is modeled with a 50 ohm link coupling (green wire). A toroid transformer is used to sample signals from the tuned circuit.
JPEG Image - 192.86 kB - 09/10/2019 at 15:48
Preview
Close up of tuning and fixed capacitors. High current doorknob (RF) caps are 25pf and 50pf NPO. Variable cap is 2 section, 100 pf per section.
JPEG Image - 535.81 kB - 08/08/2019 at 16:28
Preview
Overview of tuning box. Variable cap has insulated shaft coupling and vernier reduction drive. Other end goes to radio knob to act as a pointer.
JPEG Image - 165.51 kB - 08/08/2019 at 16:28
Preview
An 11 foot telescoping lighting pole is the support. 3-D printed clamps mount each component to the pole. Different clamps fit different sections of the pole.
JPEG Image - 100.96 kB - 07/26/2019 at 16:53
Preview
Choice of range capcitors.pdf
This design uses a high voltage air variable capacitor. Fixed RF doorknob capacitors set the range over which the variable capacitor is used to tune. This graphic shows each potential tuning range.
Adobe Portable Document Format - 39.97 kB - 07/26/2019 at 16:42
Preview
Loop size and capacitances.xlsx
Spreadsheet and graphs of the different capacitances that would be needed depending upon the loop size.
sheet - 18.53 kB - 07/26/2019 at 16:41
Download
