Servo Mount Plate.svgThe mounting shield that holds that servo motor and slides down the slot in the faceplate fixture.3.516 x 1.95 in (To be laser cut through 1/8" acrylic. File units in inches.) svg+xml - 1.07 kB - 09/22/2019 at 03:50 |
Servo Mount Plate.ai[Adobe Illustrator source file]The mounting shield that holds that servo motor and slides down the slot in the faceplate fixture. 3.516 x 1.95 in (To be laser cut through 1/8" acrylic. File units in inches.) postscript - 589.47 kB - 09/22/2019 at 03:50 |
Servo Mount Faceplate Fixture.stlThe servo motor mounting fixture that screws over the lockset's faceplate.190 x 60 x 38 mm (To be 3D printed. File units in meters.) Standard Tesselated Geometry - 114.93 kB - 09/22/2019 at 03:50 |
Servo Arm Thumbturn Rotator.stlThe rotator disk that attaches to the arm included with the servo motor and loosely fits around the lock thumbturn to spin it.41 x 41 x 16 mm (To be 3D printed. File units in meters.) Standard Tesselated Geometry - 47.54 kB - 09/22/2019 at 03:50 |
Door Handle Backer Large.stlThe larger half of the backer ring that bolts together with the door handle lever.77 x 68 x 10 mm (To be 3D printed. File units in meters.) Standard Tesselated Geometry - 361.12 kB - 09/22/2019 at 03:50 |
Door Handle Backer Small.stlThe smaller half of the backer ring that bolts together with the door handle lever.33.6 x 45.4 x 10 mm (To be 3D printed. File units in meters.) Standard Tesselated Geometry - 120.00 kB - 09/22/2019 at 03:50 |
Door Handle Lever.stlThe door handle lever that bolts together with the two backer ring pieces.180 x 68 x 18 mm (To be 3D printed. File units in meters.) Standard Tesselated Geometry - 1.49 MB - 09/22/2019 at 03:50 |
NFC Door Unlocker - Source Parts.blend[Blender source file]Contains the untriangulated source meshes for the five STLs. (To be 3D printed. File units in meters.) blend - 2.42 MB - 09/22/2019 at 03:50 |
