zeptoforth
A full-featured Forth-based RTOS for ARM Cortex-M
Public Chat
zeptoforth is a bare-metal Cortex-M Forth which includes an preemptively-multitasking, priority-scheduled RTOS. It currently supports the Raspberry Pi Pico (and other RP2040-based boards with Winbond Quad SPI flash), STM32L476, STM32F407, and STM32F746 DISCOVERY boards, and STM32F411 "Black Pill" boards, but work is planned on porting it to other boards in the near future.
zeptoforth is a portable subroutine-threaded / native code inlining Forth for Cortex-M0+/M4/M7 microcontrollers which includes a preemptively multitasking RTOS designed to be able to compile to and run from both flash and RAM (the kernel of course exists in flash).
The library of code coming with zeptoforth includes support for the following:
  • Lambda expressions
  • VALUEs, 2VALUEs, and lexically-scoped local variables compatible with DO LOOPs
  • Implicit compilation, where conditional/looping constructs are temporarily compiled during intepretation mode, executed, and then forgotten
  • Closures
  • Dynamically-scoped, task-local variables
  • Double-cell and S31.32 fixed-point arithmetic, including the usual mathematical functions
  • SysTick
  • Interrupt-driven serial IO drivers
  • A simple GPIO abstraction layer that is maximally uniform across supported platforms
  • GPIO and, where applicable, EXTI drivers
  • Arbitrary UART support, beyond the console alone
  • ADC support
  • SPI support
  • SDHC/SDXC card support
  • FAT32 filesystem and MBR partition table on SDHC/SDXC cards support
  • Support for loading code from files in FAT32 filesystems
  • Rebooting via Control-C at the console, or Reboot in zeptocom.js
  • Attention key commands via Control-T at the console, or Attention in zeptocom.js; currently the only attention key commands are 'z', which sends an exception to the main task, and 't', which, when the task monitor is active, displays information on all running task
  • An optional task monitor (note that starting creates a task dedicated to it)
  • Preemptive multitasking
  • Action scheduling including synchronous messaging between actions on single tasks
  • A disassembler
  • Moving the exception vector table into RAM so it can be arbitrarily set
  • Task notifications
  • Semaphores
  • Locks
  • Signalling exceptions on other tasks
  • Message-oriented channels
  • Message-oriented rendezvous channels (aka "fchannels")
  • Message-oriented synchronous bidirectional reply channels (aka "rchannels")
  • Message-oriented ISR-friendly channels (aka "schannels")
  • Byte-oriented streams
  • Software alarms
  • Console redirection
  • Object-orientation
  • Maps, including counted string and integer-keyed maps
  • Temporary buffers
  • An allocator
  • Memory pools
  • Task pools
  • Action pools (for the single-task event scheduler)
  • A line editor
  • LED drivers
  • Random number generator drivers (except on STM32F411 "Black Pill" boards)
  • Pseudorandom number generation support (using the TinyMT32 PRNG)
  • Best-effort fault recovery
  • swdcom support for non-UART-based terminal support
On the Raspberry Pi Pico (and other compatible RP2040 boards) it also supports the following:
  • An optional USB CDC console
  • An optional IPv4 stack for the Raspberry Pi Pico W, aka 'zeptoIP'.
  • An optional SNTP (Simple Network Time Protocol) implementation for use with zeptoIP
  • Programmable input/output (PIO)
  • Hardware watchdog
  • I2C, in both master and slave modes
  • PWM, including both input and output
  • Hardware timers
  • Realtime clocks
  • Multicore execution; note that this can be combined with multitasking on each core and multitasking constructs can be shared by both cores
Note that the random number generator is not supported on the RP2040.
On the STM32F746 DISCOVERY board and the Raspberry Pi Pico (and other compatible RP2040 boards) it also supports the following:
  • Quad SPI Flash memory
  • A block interface
  • A block editor
There is also optional support for
  • Single-cell S15.16 fixed-point numerics support
  • A profiler
  • An optional text editor for editing files in FAT32 filesystems, aka 'zeptoed'.
  • Bitmaps
  • 16-bit pixmaps
  • I2C SSD1306-based displays (currently these are only usable on the Raspberry Pi Pico (and compatible boards) as I2C has only been implemented for it as of yet)
  • 16-bit SPI ST7735S-based displays
  • Monospace bitmap fonts; note that a simple ASCII monospace bitmap font is included
zeptoforth-1.5.4.3.tar.gz
This patch-level release fixes a bug in the USB CDC driver which was causing delayed connections under both Linux and Windows (sorry but zeptocom.js under Chrome on Windows still appears to be borked) along with adding the word PROFILE::CLEAR-PROFILE to clear profiler data.
gzip - 20.46 MB - 03/14/2024 at 04:09
Download
  • 1 × A zeptoforth binary, whether just a kernel or one containing compiled Forth code (the latter is highly recommended)
  • 1 × A compatible board, such as the STM32L476 DISCOVERY, STM32F407 DISCOVERY, STM32F746 DISCOVERY, or Raspberry Pi Pico boards
  • 1 × A means to flash said board (e.g. ST-Link, or in the case of the DISCOVERY boards, a USB to USB Mini cable); in the case of the
  • 1 × A means to communicate with said board over serial or ST-Link (to enable the use of swdcom)
  • Patch-level release 1.5.4.3
    Travis Bemann03/14/2024 at 04:11 0 comments
    This patch-level release fixes a bug in the USB CDC driver which was causing delayed connections under both Linux and Windows (sorry but zeptocom.js under Chrome on Windows still appears to be borked) along with adding the word profile::clear-profile to clear profiler data.
  • Patch-level release 1.5.4.2
    Travis Bemann03/11/2024 at 01:55 0 comments
    This patch-level release adds an optional profiler and fixes a bug in SPI on the RP2040 where spi>buffer and buffer>spi would transfer DMA units rather than bytes, so if 2 bytes were specified and the data size was set to 16 bits, 32 bits would actually be transferred.
  • Patch-level release 1.5.4.1
    Travis Bemann03/09/2024 at 03:15 0 comments
    This patch-level release adds the ability to chain DMA transfers on the RP2040, modifies buffer transfers with SPI on the RP2040 to use DMA, fixes initializer to work no matter what module it is invoked inside, and fixes some minor documentation issues.
    Travis Bemann02/29/2024 at 03:50 0 comments
    This patch-level release adds functionality to the NTP client to synchronize the RP2040's realtime clock with the reported time.
  • Patch-level release 1.5.3
    Travis Bemann02/27/2024 at 03:22 0 comments
    This patch-level release adds support for dynamically-scoped, thread-local variables and fixes an introduced bug in PIO programs which was causing the wrap top address, if not specified the user, to be off by one.
  • Patch-level release 1.5.2
    Travis Bemann02/26/2024 at 01:17 0 comments
    This patch-level release updates the PIO API to support defining PIO programs with :pio and ;pio along with mark words and wrap words and words for allocating space in PIO program memories and conveniently loading PIO programs, adds support for the RP2040 watchdog, adds rounding words for S15.16 numerics, and fixes the value of pi for S31.32 numerics.
  • Patch-level release 1.5.1
    Travis Bemann02/19/2024 at 01:21 0 comments
    This patch-level release adds optional support for S15.16 single-cell fixed-point numerics, fixes a bug that was causing abnormal behavior (frequently in the form of crashing) when the user attempted to use I2C after starting the second core of the RP2040, and adds support for printing fixed-point numbers with a base up to 36.
  • Bug-fix release 1.5.0.1
    Travis Bemann02/06/2024 at 03:38 0 comments
    This bug-fix release fixes a regression where the console could not be used (i.e. it would cause a hard fault) from the first task started on core 1 of the RP2040 unless console I/O was specifically redirected first, due to a lack of initialization of the console I/O hooks in  the initialization code for core 1.
  • Minor release 1.5.0
    Travis Bemann02/03/2024 at 04:49 0 comments
    This release adds implicit compilation, where temporary anonymous words in RAM are automatically compiled whenever one executes if, begin, do, ?do, or case while in interpretation mode and, after a matching then, end (a new word matching begin that closes its scope without any branch), until, repeat, again, loop, +loop, endcase, or endcasestr is compiled, immediately executes the anonymous word in question and then promptly forgets it. (Note that anything alloted in or compiled to the RAM dictionary in question is invalidated after this, so it is not safe to, say, use [: ... ;] to create a quotation and then pass it to task::spawn from within this temporary anonymous word.) This release also makes fixes to zeptoed and local/loop variables (which previous would break if there were any more than 127 at a time in a given scope), and makes a minor improvement to fat32-tools::list-dir, specifically including file sizes in the readout.
  • Patch-level release 1.4.1
    Travis Bemann01/24/2024 at 00:37 0 comments
    This patch-level release fixes issues with sqrt (which previously could get stuck in an infinite loop with certain arguments) and with sin and cos (which would overflow with large arguments, causing erroneous returned values), optimizes c!, h!, !, 2!, c+!, h+, and +!, adds turtle graphics for use with ST7735S displays, adds a raytracing demo for use on such displays, and makes some additions and fixes to the documentation.
View all 225 project logs
zyndram wrote 06/11/2023 at 12:14 point
Can You create a working device with screen, keyboard, network (irda) and usb?
for example working time on one charge a month
Travis Bemann wrote 06/11/2023 at 17:01 point
As for USB, on the RP2040 it supports USB CDC as a console, in the place of a serial console. Note that this is as a USB slave rather than host, so it has no way of communicating as a host with its own slaves (such as keyboards or mice).
As for displays, it currently has optional support on the RP2040 for I2C SSD1306-based monochrome bitmap OLED screens, and this could be extended to other bitmap screens such as those old Nokia ones. If you want support for VGA-based displays you could implement something using PIO, as this has been done before using that.
As for networking, there are no plans to support IrDA - even though you could implement support for an IrDA peripheral on one of the STM32 platforms. However, I am currently at work on a driver for the CYW43439 WiFi chip on the RPi Pico W. Note though that it will be a while until I get WiFi support working since even when I get my driver working I will need to implement an IP stack using it.
villaromba wrote 01/25/2023 at 15:49 point
On a PICO what RTC are you using and to what pins on the PICO, also what pins for the SD CARD. I'm thinking of using the Maker Pi Pico (Cytron) which I already have. So the SD pins are fixed so where do I tell Forth where it is connected?
Travis Bemann wrote 01/25/2023 at 21:18 point
On the Pico I am using the RP2040's on-chip RTC using the 12 MHz XOSC crystal. There is a pin for a separate crystal, GPIO 20, but this is not supported currently by zeptoforth.
teraz wrote 05/05/2022 at 10:37 point
please add password for loging (meybe OTP)
password and hardware switch for replace firmware
Travis Bemann wrote 05/06/2022 at 13:51 point
What do you mean? zeptoforth has no logging independent of what it writes to serial. Also, about securing the firmware, zeptoforth has zero built-in security by design, and even if it did, the only way to prevent writing to firmware via SWD on some platforms would be to set bits to lock out SWD, and to my knowledge there is no means to lock out uploading firmware via the USB mass storage device on the Raspberry Pi Pico.
teraz wrote 05/07/2022 at 12:21 point
I see console, i need password protect for no everyone can write in console/terminal
Travis Bemann wrote 05/07/2022 at 16:17 point
If you want to lock out the console on bootup except for someone entering a password I would recommend something like:
compile-to-flash
: hash ( c-addr u -- x ) ( add your hash algorithm here ) ;
: init ( -- )
    init
    begin
        cr ." Password: " refill token ?dup if
            hash [ s" your-password" hash ] literal =
        else drop false then
   until
Replace your-password with the password you intend to use (because it is hashed at compile-time this password will not be in the compiled code in flash). Also replace the hash algorithm with something sane; for testing purposes I used:
: hash ( c-addr u -- x ) 0 0 -rot ?do dup 7 lshift swap 25 rshift or over c@ xor swap 1+ swap loop nip ;
However, that's not secure by any means. (Note that truly using a secure hash rather than just 32 bits of it would require significant modifications of the above code.
Also note that this will only keep out the most basic of attackers, because there is nothing stopping them from simply reflashing the whole board or reaching into the board with SWD (some MCU's have bits for locking out SWD but these are MCU-specific and i am not familiar with the operation of these myself).
Also note that this must be compiled after any other implementations of init or otherwise these will execute (provided they follow the convention of each init calling the init before it before doing its operations) after the password is entered successfully.
teraz wrote 05/19/2022 at 21:18 point
this is not otp
Travis Bemann wrote 05/20/2022 at 01:19 point
Well, anything truly OTP will be very hardware-specific. What I gave there was a general solution to passwording zeptoforth, not a means to permanently lock the user out of the device. Some devices, such as the RPi Pico, have no OTP capability in the first place.
Thomas wrote 04/13/2020 at 08:01 point
I like the story behind your project a lot! Since you're using e4thcom some of Manfred Marlow's approaches to the little Forth I'm maintaining might also be useful for your Forth. Also it's quite possible that my codeload.py works with minor adaptations :-)
Travis Bemann wrote 04/13/2020 at 12:05 point
The main adaptation that would be needed is that it would need to wait until it receives ACK to send another line of code, and it would need to treat NAK as an indicator of an error indicating to stop ending any more data. This is why with e4thcom it is used in noforth mode, because noforth behaves in this fashion.
Thomas wrote 04/13/2020 at 16:09 point
I remember I had a long discussion with Manfred about ACK/NACK vs. OK/? - he didn't like the solution he made for noforth too much and made a point of using the "human readable" handshake with OK and ? (for error). What's your reason for using ACK/NACK?
Travis Bemann wrote 04/13/2020 at 18:28 point
My reason to do ACK and NAK is that it would signal success versus failure without relying on the textual content of what is output - in zeptoforth an exception can really result in anything being output while ACK and NAK could be transparently added to all prompts and all errors without any further changes being necessary - and there was a premade mode in e4thcom to use ACK and NAK.
(Note that I am responding to this post because hackaday.io is not letting me reply to your other post.)
Thomas wrote 04/16/2020 at 18:55 point
I didn't notice your reply, sorry. Hint: in HaD discussions you can simply reply to the post someone else replied to.
OK, now I understand your preferences. When I started this I first tried to work with an XON/XOFF handshake, at least until I figured the following out about USB-serial converters on Linux: https://github.com/neundorf/CuteCom/issues/22
Travis Bemann wrote 04/17/2020 at 15:05 point
Personally I would prefer hardware flow control, but unfortunately the USB-serial dongle I am using to communicate with the STM32F407 DISCOVERY board lacks pins for RTS/CTS, and the serial over USB connection built into the STM32L476 DISCOVERY board has no option for hardware flow control in the first place.
Travis Bemann wrote 04/16/2020 at 18:01 point
I looked at the code for codeload.py and noticed that is coded for Python 2.7, which is no longer maintained. Could you do a port for Python 3? This could be very useful for people who do not run Linux (and thus e4thcom is not a feasible option, as apparently people have not had luck with FreeBSD's Linux compatibility layer with it). (I could add more screen support for also adding XON and XOFF, but screen still would not support loading files from within other files with anything like #include or #require.)
Thomas wrote 04/16/2020 at 18:39 point
Sure I can port it to Python 3 :-) To be honest, when I wrote it I didn't know much Python and 2.7 was the default on the Ubuntu 14.04 I was using then.
Do you know of anyone who uses the e4thcom 64bit binary on WSL 2?
Travis Bemann wrote 04/17/2020 at 14:51 point
I have not heard of anyone trying 64-bit e4thcom with WSL 2, but then, I have not heard of anyone who has used WSL 2 in the first place. Most of the people I know in #forth on freenode are either Linux (and not Linux on top of Windows) or BSD users.
Thomas wrote 04/18/2020 at 08:50 point
I gave it a try. It appears to work but it's not fully tested:
https://gist.github.com/TG9541/0b48bd49854cc865469515697b5185f6
Thomas wrote 04/18/2020 at 13:01 point
I tried telnet to ucSim with the python3 variant - Python3 "byte array vs. str"  issues, of coursed. Unfortunately I get timeouts after fixing it. That's very difficult to debug. The serial interface transfer, which is likely the one you're most interested in, should work anyway.
Travis Bemann wrote 04/19/2020 at 16:19 point
Could you add a copyright notice and license block to codeload3.py so I can incorporate it, with some minor modifications, to the zeptoforth codebase? I should note that there is no such thing as the public domain in Germany.
Thomas wrote 04/19/2020 at 18:24 point
Sure, I'll do that. MIT is OK, I s'pose?
Edit: done
Travis Bemann wrote 04/19/2020 at 18:52 point
That would work, particularly since the MIT license is GPL-compatible.
Travis Bemann wrote 04/19/2020 at 21:41 point
I put my changes to codeload3.py to make it work with zeptoforth in my fork of your gist, and I will include this with zeptoforth so users can upload code without relying on e4thcom.
Elliot Williams wrote 04/13/2020 at 07:41 point
Cool!  Going to have to check this out.
Lemme see if I have a 407 Disco around here somewhere...
I agree that Forth misses lambdas, just b/c it's hard to think up good names all the time.
Although on multitasking/timers, honestly, I end up just writing "begin do_something 100 ms again", which works as well, if your "ms" definition has a "yield" in it.  But this keeps the chip from going into a low-power mode, b/c it's always round-robinning into delay statements.  If the scheduler knew...
So yeah.  I'm going to have a peek at your multitasking setup.
Travis Bemann wrote 04/13/2020 at 12:00 point
I would appreciate more people trying it out, even though that requires their owning the same hardware as myself. (It is hard for me to maintain the code for hardware I do not own, e.g. I cannot create zeptoforth_full binaries without physically owning the hardware in question.)
Lambdas are a feature missing, unfortunately, from most Forths, even though there are a few with them, such as Retro (of course Retro is not a conventional Forth by any means).
The multitasker is designed to put the MCU to sleep when no task is actively executing, even though it wakes up the processor when a SysTick occurs, when a byte is received over a USART, or, if data is pending in the serial TX circular buffer and the USART TX shift register becomes free. So if one writes:
: foo begin do-baz 100 ms again ;
' foo 256 256 256 spawn constant foo-task
foo-task task-enable
it will sleep the MCU, aside from it getting woken up by SysTicks and by any input the user feeds into the REPL.
Travis Bemann wrote 04/18/2020 at 17:37 point
You said you might try it out on the F407. If you had any problems with the zeptoforth_full-[version].bin file for the F407, there were issues with it being corrupt, so try it out with the latest release binaries, where I made sure to check that it now works.
crun wrote 04/12/2020 at 20:44 point
Could you explain why vs mecrisp?
Re M0, you say "it relies on key features of the Thumb-2 instruction set which are missing from the Thumb-2 instruction set". Could you clarify?
Travis Bemann wrote 04/12/2020 at 21:22 point
To be completely honest, it fits much of the same niche as Mecrisp-Stellaris, but there being one Forth for a platform has not stopped anyone from making another (e.g. there already was a Cortex-M Forth before Mecrisp-Stellaris, namely Riscy Pygness). This project exists largely because I wanted to create a bare-metal native code embedded Forth of my own, and the STM32L4 and STM32F4 series microcontrollers were an attractive target, big enough to fit a good-sized Forth with plenty of room to spare, with good documentation for peripherals, and without being effectively a PC on a chip (e.g. the Raspberry Pi boards) with peripherals that may require proprietary binary blobs and thus not amenable to development by an individual such as myself.
About the M0, the issue is that 32-bit literals are difficult to implement without 16-bit low and 16-bit high immediate MOV/MOVT instructions, and while I tried to implement literals that use a mixture of MOVS, LSLS, and ORRS instructions the problem is that when allocating space for a literal ahead of time, and then writing to it later, it is hard to predict how long that sequence of instructions will be (unless one assumes the very longest length and then fills out the rest of the space with NOPs). So as a result I am focusing on Cortex-M3/M4 for now, and will  implement support for the Cortex-M0 later if I see the need for it.
crun wrote 06/10/2020 at 07:35 point
Looking into M4 because of the dsp floating point performance. So 4th for the little F411 dip boards would be ok with me.  Interesting how to integrate Forth with the arm dsp libraries though.
alessandro.cordova wrote 04/11/2020 at 17:43 point
Amazing
