CP/M-86 with AUTO-SWITCH to CP/M-80
03/24/2021 at 17:32 • 0 commentsThanks to Stephen Hunt, the author of the VCPM15 utlity, it is now possible to automatically execute either CP/M-86 or CP/M-80 programs without the need of the VCPM emulator program that he wrote back in the 80s.
See how in the new paragraph: "CP/M-86 WITH AUTO-SWITCH TO CP/M-80" in the Details section.
iLoad: How setup an 8088 cross-assembler automated toolchain (Windows)
06/20/2020 at 10:17 • 0 commentsI've added a new paragraph on how to setup an assembler (8088) automated toolchain under Windows using the iLoad boot mode.
See the "ILOAD: HOW SETUP AN 8088 CROSS-ASSEMBLER AUTOMATED TOOLCHAIN (WINDOWS)" paragraph in the Details section.
CP/M-80 emulation under CP/M-86
06/10/2020 at 16:49 • 0 commentsI've released a new SD image that adds in the drive F: of the CP/M-86 Disk Set a CP/M-80 emulator under CP/M-86 using the V20 8080 mode (VCPM15.CMD).
In this way it is also possible run Catchum or send/receive a file with XMODEM:
For more info see the "EMULATING CP/M-80 UNDER CP/M-86" paragraph in the Details section.
CP/M-86 is out!
06/04/2020 at 17:59 • 0 commentsCP/M-86 is out!
Remember to update both the IOS firmware and the SD image (see Files section):
Testing CP/M-86...
06/02/2020 at 17:04 • 0 commentsCurrently testing CP/M-86:
The custom Bios sizes the installed RAM (128/512/1024KB) and changes the CP/M-86 available TPA accordingly.
Here Turbo Pascal for CP/M-86 and Wordstar 3.3 for CP/M-86:
New IOS with CP/M 2.2 (8080 mode) is out!
05/20/2020 at 17:08 • 0 commentsThe new IOS with CP/M 2.2 (8080) is out in the Files section:
Remember to update the SD image too!
The Details section will be updated with new info ASAP...
Testing CP/M 2.2 (8080 mode)...
05/18/2020 at 12:00 • 0 commentsI'm currently testing CP/M 2.2 using the 8080 mode:
Of course only the CP/M applications strictly using 8080 machine code can be used here.
