track 4.jpgone long track, now to make another one.JPEG Image - 4.04 MB - 06/19/2020 at 06:05 |
voltage controllers.jpgvoltage regulators for rc controller and servos for gunJPEG Image - 2.95 MB - 06/19/2020 at 06:05 |
whole hull.jpgthe hull is coming together nicelyJPEG Image - 3.08 MB - 06/19/2020 at 06:05 |
Track side.jpga lot of droop on that track without the road wheels and tensionJPEG Image - 2.95 MB - 06/19/2020 at 06:05 |
upper hull side view.jpgupper hull from the sideJPEG Image - 2.29 MB - 06/19/2020 at 06:05 |
track adjuster.jpgeye bolt used to adjust tension on the tracksJPEG Image - 2.45 MB - 06/19/2020 at 06:05 |
motor controller and voltage regulators.jpgmotor controller and voltage regulatorsJPEG Image - 2.76 MB - 06/19/2020 at 06:05 |
track 2.jpgtons of bolts and hingesJPEG Image - 2.39 MB - 06/19/2020 at 06:05 |
track 1.jpgstart of track assembly. 2 inch hinges bolted together with stainless steel bolts. the bolts serve as guides to help keep the tracks on the drive and road wheels.JPEG Image - 2.26 MB - 06/19/2020 at 06:05 |
side tracks 2.jpgtrack in place looking like a tankJPEG Image - 3.12 MB - 06/19/2020 at 06:05 |
side tracks.jpgtrack in place looking like a tankJPEG Image - 3.15 MB - 06/19/2020 at 06:05 |
side drive.jpgdrive sprocket, idler wheel, and track carrier wheelJPEG Image - 3.09 MB - 06/19/2020 at 06:05 |
motor contoller mount.jpgMotor controller mountJPEG Image - 3.38 MB - 06/19/2020 at 06:05 |
side drive track 2.jpgtracks around drive sprocketJPEG Image - 2.97 MB - 06/19/2020 at 06:04 |
side drive tracks.jpgTracks around drive sprocketJPEG Image - 3.16 MB - 06/19/2020 at 06:04 |
road wheels.jpgRoad wheelsJPEG Image - 2.80 MB - 06/19/2020 at 06:04 |
rear track close up.jpgclose up of the track on the rear idler wheelsJPEG Image - 2.80 MB - 06/19/2020 at 06:04 |
road wheels and tracks.jpgroad wheels with the tracks in placeJPEG Image - 2.68 MB - 06/19/2020 at 06:04 |
on all fours.jpgfinally setting on the tracks and ready to rollJPEG Image - 3.22 MB - 06/19/2020 at 06:04 |
rear motor vent.jpgmotor vent on rear of the tankJPEG Image - 2.14 MB - 06/19/2020 at 06:04 |
motor layout.jpgMotor layoutJPEG Image - 3.57 MB - 06/19/2020 at 06:04 |
motor controller compartment.jpgCompartment for the motor controller. It has springs that attach to the controller for shock absorptionJPEG Image - 3.09 MB - 06/19/2020 at 06:04 |
rear motor vent 1.jpgRear vent for motor (on real tank) used to circulate air on my motors with a computer fan.JPEG Image - 2.22 MB - 06/19/2020 at 06:04 |
rear hull.jpgRear hull coming togetherJPEG Image - 2.97 MB - 06/19/2020 at 06:04 |
front half of upper hull.jpgbeginning the upper hull - lots of tough angles here. Glad I'm working in wood.JPEG Image - 3.42 MB - 06/19/2020 at 06:04 |
hull cutouts.jpgcutouts in hullJPEG Image - 2.64 MB - 06/19/2020 at 06:03 |
hull details.jpghull detailsJPEG Image - 2.24 MB - 06/19/2020 at 06:03 |
drive sprocket 1.jpgdrive sprocket close upJPEG Image - 3.15 MB - 06/19/2020 at 06:03 |
fenders 1.jpgfendersJPEG Image - 2.14 MB - 06/19/2020 at 06:03 |
fender rear.jpgrear fender detailJPEG Image - 2.44 MB - 06/19/2020 at 06:03 |
front hull.jpgfront hullJPEG Image - 2.10 MB - 06/19/2020 at 06:03 |
fenders 2.jpgfendersJPEG Image - 2.13 MB - 06/19/2020 at 06:03 |
bushings.jpgbushings and bearings for drive axles and bogiesJPEG Image - 2.26 MB - 06/19/2020 at 06:03 |
bogies.jpgroad wheel bogiesJPEG Image - 2.46 MB - 06/19/2020 at 06:03 |
base2.jpglower hullJPEG Image - 2.97 MB - 06/19/2020 at 06:03 |
battery compartment.jpgbattery compartment with charging port and RC controller power switchJPEG Image - 2.98 MB - 06/19/2020 at 06:03 |
p2.jpgDetailed DrawingsJPEG Image - 51.45 kB - 06/19/2020 at 06:03 |
bogie axles.jpgroad wheel bogies with axlesJPEG Image - 2.63 MB - 06/19/2020 at 06:03 |
basic upper hull.jpgupper hull beginning to take shapeJPEG Image - 2.88 MB - 06/19/2020 at 06:03 |
Base1.jpglower hull beginning to take shapeJPEG Image - 2.71 MB - 06/19/2020 at 06:02 |
base sides.jpglower hull sidesJPEG Image - 2.77 MB - 06/19/2020 at 06:02 |
base painted.jpglower hull paintedJPEG Image - 2.89 MB - 06/19/2020 at 06:02 |
base rear.jpglower hull rearJPEG Image - 2.52 MB - 06/19/2020 at 06:02 |
base front.jpgLower hull frontJPEG Image - 2.43 MB - 06/19/2020 at 06:02 |
access door open.jpgAccess door to RC power and charging port held closed with magnetsJPEG Image - 2.83 MB - 06/19/2020 at 06:02 |
base and motors.jpgLower hull and motorsJPEG Image - 2.55 MB - 06/19/2020 at 06:02 |
video tracks working.mp4Rolling tracks to adjust tensionMPEG-4 Video - 6.27 MB - 06/19/2020 at 06:02 |
access door closed.jpgAccess door to RC power and charging port.JPEG Image - 2.95 MB - 06/19/2020 at 06:02 |
is-2-armour-1.pngDetailed DrawingsPortable Network Graphics (PNG) - 329.70 kB - 06/19/2020 at 06:02 |
p3 (1).jpgDetailed DrawingsJPEG Image - 49.46 kB - 06/19/2020 at 06:02 |
fenders 3.jpgFendersJPEG Image - 1.90 MB - 06/19/2020 at 06:02 |
base and axle.jpgAxle fit into bearings.JPEG Image - 2.65 MB - 06/19/2020 at 06:02 |
axle close up.jpg5/8" drive axleJPEG Image - 2.44 MB - 06/19/2020 at 06:02 |
front fender.jpgFront fender detail and headlightJPEG Image - 1.78 MB - 06/19/2020 at 06:01 |
zVwJG5V.jpgDetailed DrawingsJPEG Image - 116.86 kB - 06/19/2020 at 06:01 |
sd_kfz_138_2_jagdpanzer_38_t_hetzer-72386.jpgDetailed DrawingsJPEG Image - 80.56 kB - 06/19/2020 at 06:01 |
panzerjager_g13_hetzer-75300.jpgDetailed DrawingsJPEG Image - 123.24 kB - 06/19/2020 at 06:01 |
panzer2.gifDetailed DrawingsGraphics Interchange Format - 139.14 kB - 06/19/2020 at 06:01 |
p3.jpgDetailed DrawingsJPEG Image - 49.46 kB - 06/19/2020 at 06:01 |
hetzer_16.jpgDetailed DrawingsJPEG Image - 260.46 kB - 06/19/2020 at 06:01 |
p1.jpgDetailed DrawingsJPEG Image - 64.77 kB - 06/19/2020 at 06:01 |
hetzer.jpgDetailed DrawingsJPEG Image - 21.30 kB - 06/19/2020 at 06:01 |
78319_10151102112707467_2068635587_o.jpgDetailed DrawingsJPEG Image - 63.78 kB - 06/19/2020 at 06:01 |
