VorEnder 5 Core XY 3D Printer
Voron 2.4 inspired build using Ender 5 3D Printer frame profiles as a base and some parts laying around :)
VorEnder 5
Frame: Aluminum profiles coming from Ender 5
CoreXY Kinematics based on Voron 2.4 (250x250)
Afterburner Extruder, TriangleLab Swiss Hotend
3 points support auto leveling Heat Bed
Fystec Spider with TMC2209 drivers
Raspberry Pi 4 8GB + Klipper + Octoprint
Frame VorEnder5.stl
Standard Tesselated Geometry - 4.68 MB - 02/14/2023 at 22:15
Download
hotend_fan_mount_LED v3.stl
Standard Tesselated Geometry - 184.65 kB - 02/12/2023 at 03:08
Download
Frame rear left bottom corner v3.stl
Standard Tesselated Geometry - 79.18 kB - 01/30/2023 at 05:36
Download
led_strip_housing.stl
Standard Tesselated Geometry - 69.42 kB - 01/29/2023 at 18:29
Download
wiki Fysec Spider V22.url
url - 153.00 bytes - 01/28/2023 at 19:09
Download
View all 40 files
View all 31 components
View all 25 project logs
penalver wrote 12/02/2021 at 17:28 point
Hello, I plan to start designing the VORENDER5 PLUS! Do you have assembly plans for the machine?
Thank you for your work ... it's a good job ...
Gerben wrote 11/11/2021 at 18:49 point
you ask for 2 times 200 M3, M5 what length???
Max wrote 10/19/2021 at 14:15 point
Hey
Could you tell me the difference between front idler 3mm / normal?
Tryed to figure it out by uplaoad date...
Nice project by the way.
Nickchesshir wrote 07/08/2021 at 06:04 point
What length of belt was used on this project? 4x quantity x length?
Also with the screw amounts and corner brackets, are these for a brand new build even for the frame?
