Pedal Powered Display Wiring Diagram.pdf
Adobe Portable Document Format -
357.21 kB -
04/06/2022 at 17:33
Preview
Sun V3.DXF
AutoCAD DXF -
35.99 kB -
04/06/2022 at 17:28
Download
Rear Control Panel.DXF
AutoCAD DXF -
24.17 kB -
04/06/2022 at 17:28
Download
Lightning V1.DXF
AutoCAD DXF -
26.94 kB -
04/06/2022 at 17:28
Download
Modified Sun Drive Spur Gear.DXF
AutoCAD DXF -
35.31 kB -
04/06/2022 at 17:28
Download
Sun Spacer.DXF
AutoCAD DXF -
21.87 kB -
04/06/2022 at 17:28
Download
Rear Control Panel Spacer.DXF
AutoCAD DXF -
23.31 kB -
04/06/2022 at 17:28
Download
Modified Sun Driven Spur Gear.DXF
AutoCAD DXF -
48.05 kB -
04/06/2022 at 17:28
Download
Front Control Panel.DXF
AutoCAD DXF -
28.47 kB -
04/06/2022 at 17:28
Download
Annotated PCB
Portable Network Graphics (PNG) -
528.82 kB -
04/06/2022 at 15:38
Preview
Schematic_Cog Circuit Wall_2022-04-06.pdf
PCB Schematic
191.25 kB -
04/06/2022 at 12:19
Preview
SCH_Cog Circuit Wall_2022-04-06.json
Easy EDA File if you want to edit the PCB
JavaScript Object Notation (JSON) -
193.81 kB -
04/06/2022 at 12:15
Download
train3.wav
Waveform Audio File Format (WAV) -
6.21 MB -
04/06/2022 at 12:14
Download
light.wav
2.57 MB -
04/06/2022 at 12:14
Download
plane.wav
2.65 MB -
04/06/2022 at 12:14
Download
thunder.wav
1.17 MB -
04/06/2022 at 12:14
Download
Gerber_PCB_Cog Circuit Wall_2.zip
Gerber File for creating the PCB
Zip Archive -
153.40 kB -
04/06/2022 at 12:13
Download
BOM_PCB_Cog Circuit Wall_2_2022-02-24.csv
Bill of Materials File for Creating the PCB
Comma-Separated Values -
10.00 kB -
04/06/2022 at 12:13
Download
PickAndPlace_PCB_Cog Circuit Wall_2_2022-02-24.csv
Pick and Place FIle for creating the PCB
15.65 kB -
04/06/2022 at 12:13
Download
