Spectral-Database-1.0-master (3).zipThis is the latest installment to my spectral database on github, there are now 125 absorption and emission scans. PNG pics are also included relative to the particular studies being done.x-zip-compressed - 3.19 MB - 04/15/2017 at 14:16 |
Spectral-Database-1.0-master (2).zip4 new raw data files added, parts 1 and 2 from; Effects of Solvents on Fluorescence of Biological Dyes done on 8/26/2016x-zip-compressed - 1.70 MB - 04/13/2017 at 15:00 |
Spectral-Database-1.0-master.zipThis is the begining of my spectral database collection project over at Githubx-zip-compressed - 1.49 MB - 04/13/2017 at 08:31 |
FIXED cuvette holder FEB 2 (Meshed).stl*UPDATED: 2/5/2017re-designed the Raman filter slot again, I found a less expensive Raman edge filter at Thorlabs that will work just fine, so the new slot is now 25.5 x 4.45mm and 39mm deep so the filter is at 12.5mm center line. Standard Tesselated Geometry - 1.41 MB - 02/05/2017 at 13:12 |
25 x25 x 6mm diffraction hologrphc done (Meshed).stlUPDATE 1/17/2017:Holographic Diffraction grating mount holder. Dimensions; 27 x 27x with a 6mm width slot for grating mount. Inlayed 2mm at slot bottom.Standard Tesselated Geometry - 597.64 kB - 01/17/2017 at 23:07 |
40mm Lens Holder Coupler assembly fixed (Meshed).stlUPDATE 1/17/2017:Widened the dia. of the coupler and inner dia. the 3D printing came out with a little shrinkage so I had to fix that.Standard Tesselated Geometry - 376.74 kB - 01/17/2017 at 23:07 |
20mm dia locking sleeve (Meshed).stllens locking sleeve for 2nd lens chamberStandard Tesselated Geometry - 98.71 kB - 12/22/2016 at 20:57 |
ALL mounting holes cut dec 16 main enclsr (Meshed).stlRe-designed Main enclosure, 203 X 152 X 74 mm without Lid.All mounting holes are pre-cut and exactly placed. Standard Tesselated Geometry - 5.08 MB - 12/16/2016 at 21:03 |
Square mirror mount assembly complete (Meshed).stlUPDATED: 5:14 PM 12/13/2016 25 x 25 14mm/ 12mm depth @ center W/3.2mm wide thickness to accomodate silver coated mirror.Standard Tesselated Geometry - 234.75 kB - 12/13/2016 at 22:14 |
Updated CMOS camera mount DEC 13 (Meshed).stlUPDATED @ 2:02 PM 12/13/2016 Raised the base plate 10.83mm for a total height of; 50.83mm (2") M4 mounting holes cut on bottomStandard Tesselated Geometry - 1.38 MB - 12/13/2016 at 19:01 |
32mm lens holder W 25mm inlay filter rear side (Meshed).stlUPDATED: 12/12/2016 6:45PMRe-designed 32mm lens holder, rear face FIXED 25mm inlay for longpass edge filter/ 25mm dia x 8mm deep. - 404.18 kB - 01/17/2017 at 23:07 |
Enclosure Lid complete (Meshed) nov 19.stlLid for main enclosure.Standard Tesselated Geometry - 694.22 kB - 11/20/2016 at 10:06 |
