A series of trends in controllers for competitive fighting games have led to the popularity of low-profile, all-button (aka "stickless" or "Hit Box-style") controllers using mechanical keyboard switches. The vanguard here includes the MPress and the Snack Box Micro. However, there are a few issues with the available offerings. The only commercial options with support for PS4 — the de facto standard tournament platform for the fighting game community (FGC) — are only sold in the US, making them especially expensive for players elsewhere in the world. DIY offerings typically require 3D-printed chassis, which typically require a harsh tradeoff between expense and aesthetics (not to mention durability), and struggle to provide PS4 compatibility due to Sony's authentication system for controllers.
Thus, having recently become frustrated with the weight and bulk of my very high-quality Blunderbuss controller, I decided to design a DIY solution for such low-profile controllers, that would support commercial PS4 encoders ("PCBs" in FGC lingo). I aim to design something that uses off-the-shelf parts where possible, and laser-cut panels wherever necessary, thus making the controller viable and affordable to build anywhere in the world.
I am making customisation a big focus. I want a builder to be able to adapt the design to their needs without requiring much technical skill with e.g. CAD software.
Files
Standoff_Sprued.stlUNTESTED "Release candidate" file for standoffs required to mount the switch plate to the frame. 3D print this.Standard Tesselated Geometry - 721.27 kB - 07/14/2022 at 08:06 |
SwitchPlate.dxfUNTESTED "Release candidate" file for the switch plate, the panel that holds the keyboard switches. Laser cut this from 1.5 mm aluminium.AutoCAD DXF - 53.08 kB - 07/14/2022 at 08:06 |
JackPanel.dxfUNTESTED "Release candidate" file for the panel that holds the connectors (USB etc). Laser cut this from 1.5 mm aluminium.AutoCAD DXF - 25.48 kB - 07/14/2022 at 08:06 |
TopPanel.dxfUNTESTED "Release candidate" file for the top panel of the enclosure. Laser cut this from 1.5 mm aluminium.AutoCAD DXF - 26.97 kB - 07/14/2022 at 08:06 |
TopPanel_Acrylic.dxfUNTESTED "Release candidate" file for the acrylic cover for the top panel of the enclosure. Laser cut this from 1.5 mm aluminium.AutoCAD DXF - 26.51 kB - 07/14/2022 at 08:06 |
Components
- 1 × T-slot aluminium extrusion 20×20×265 mm 270 mm minus twice the external depth of an end cap
- 2 × T-slot aluminium extrusion 20×20×125 mm
- 2 × T-slot aluminium extrusion 20×20×89 mm 91.5 mm minus twice the external depth of an end cap
- 4 × Gusseted corner bracket 20×20 mm
- 4 × T-slot extrusion end cap 20×20×2.5 mm Dimensions reflect size when installed
ShareDiscussions
You would need to customise this design. I don't know what type of encoder knob would be best, but for example some of the Brook Fighting Boards do support analogue input, so you could wire an encoder to an analogue axis to support Tempest.
The Pangolin fighting game controller platform revolutionizes gaming with its innovative design. Combining ergonomic precision and responsive controls, it offers an immersive gaming experience. For those looking to enhance their gaming journey, they should definitely get the details about 1Xbet casino bonus codes that provides exciting opportunities. To elevate your gaming adventures.
