85mmWheel-23.STL
85mm Wheel for the R2Pv1-OmniBot1 robot kit.
Standard Tesselated Geometry - 1.58 MB - 12/07/2016 at 23:50
Download
UltraSoniceFrontMount-4-OmniRover.STL
Simple mounting bracket that can accommodate a Parallax PING, or a SRF-05 or HC-SR04 UltraSonic sensor.
Standard Tesselated Geometry - 18.44 kB - 12/07/2016 at 23:48
Download
WheelCup-4-OmniRover.STL
The key bracket that connects the wheel servomotors to the base R2Pv1-OmniBot1 robotic platform.
Standard Tesselated Geometry - 220.00 kB - 12/07/2016 at 23:47
Download
SpeakerBox.STL
Small speaker enclosure that is tacked down on top of mounting plate in a convenient position.
Standard Tesselated Geometry - 57.89 kB - 12/07/2016 at 23:46
Download
BasePlate-4-OmniRover.DXF
Main mounting plate that is laser cut from 3mm or thicker plastic or Finnply etc...
AutoCAD DXF - 608.98 kB - 12/07/2016 at 23:45
Download
