PhatStats PC Performance TFT Display
Arduino TFT PC Performance Monitor with Client software
PhatStats ili9341 TFT PC Performance Monitor Display
PhatStats (TFT) form an Arduino serial display. HardwareSerialMonitor is a PC serial client, both are written by Rupert Hirst and Colin Conway.
HardwareSerialMonitor Windows client reads the hardware statistics from the PC.
This data is forwarded over the hosts’ serial  port to an Arduino compatible micro processor. It is then, displayed using the Phat-Stats sketch.
This project, assumes you have a above average experience with Arduino, the IDE and the compatible boards available.
The HardwareSerialMonitor was designed for dedicated GPU's . Your mileage may vary with Integrated Graphics
To help with construction there are hook up guides, links below:
Phat-Stats ILI9341 TFT Display Hook up Guide
Going Forward:
The project needs to be ported over to LibreHardwareMonitor , a fork of OpenHardwareMonitor  for future support, as this gets a lot more updates for new PC hardware. If anyone can help please get in touch, thanks.
http://tallmanlabs.com
http://runawaybrainz.blogspot.com/
https://github.com/koogar/HardwareSerialMonitor
https://github.com/koogar/Gnat-Stats
Gnat-Stats (OLED) has moved to a new project page here
The above software/code is licensed under the following terms:
GPL v3
Gnat-Stats, Phat-Stats & Hardware Serial Monitor Copyright (C) 2016 Colin Conway, Rupert Hirst and contributors
This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program; If not, see http://www.gnu.org/licenses/.
HardwareSerialMonitor only was inspired by Psyrax's "SerialSender". Psyrax is given attribution and thanks, by being an honorary member of the project.
WeeStatServer-0.5.2_Libre.0.9.3-pre256_Binary.zip
Alternative to HardwareSerialMonitor but uses LibreHardwareMonitor libraries. Requires .net6
x-zip-compressed - 3.96 MB - 10/06/2023 at 15:16
Download
HardwareSerialMonitor_v1.4.4_9600_OHM.0.9.6.1.PR_NET4.8_Binary.zip
added experimental Intel Jasper Lake Support added experimental Intel Rocket Lake Support added experimental Intel AlderLake support added Alde Lake Mobile support added Intel RaptorLake support Boris Vogel https://github.com/BrsVgl/openhardwaremonitor
x-zip-compressed - 1.46 MB - 09/22/2023 at 11:57
Download
x-zip-compressed - 171.34 kB - 06/20/2023 at 00:27
Download
x-zip-compressed - 272.40 kB - 06/20/2023 at 00:24
Download
TachoStats_V3.1.7.1_SeeedRoundDisplay.zip
https://www.seeedstudio.com/Seeed-Studio-Round-Display-for-XIAO-p-5638.html Seeed Studio Round Display for XIAO - 1.28-inch round touch screen, 240×240 resolution
x-zip-compressed - 180.38 kB - 06/20/2023 at 00:07
Download
View all 11 files
View all 8 project logs
View all instructions
bliznetsov.daniil wrote 4 天前 point
Hi, I decided to make a project on Gnat-Stats SSD1306 OLED Display https://runawaybrainz.blogspot.com/2021/03/phat-stats-ssd1306-oled-hook-up-guide.html
But I ran into a problem, my i5 10400f processor does not show the temperature, the video card does, but the processor does not, can you tell me how to fix it
joellepiontkowskik.e.n.q2255 wrote 10/03/2023 at 19:43 point
Hello
Is there a way to use this project on Linux based systems?
Thank in advance
Igor wrote 03/01/2023 at 13:46 point
Hello. I am using stm32 .
The display does not show used GPU memory and shader frequency.
And also in the frequency of memory and used memory some extra characters.
Is there any way to fix this?
How to change screen rotation on boot?
I don't use an encoder.
https://postimg.cc/yJTxR3TW
Thank you.
Chelik wrote 02/14/2023 at 22:54 point
Hi, can you please tell me how to solve this problem? :)
https://ibb.co/yFN0q9C
Rupert Hirst wrote 02/18/2023 at 19:11 point
Not much information to go off
Chelik wrote 02/19/2023 at 16:26 point
I used stm32, installed all required drivers, loaded the boot file through the ftdi module. After installing all the required libraries, selected the board, com port, pressed "Check", then "Load". After that a splash screen appeared with this bug, ran HardwareSerialMonitor, selected the com port - the result is as shown in the link above
sikorskiy-vitaliy wrote 01/31/2023 at 22:23 point
Hello. Tell me, no one has a project lying around in the NodeMCU ESP8266 + TFT ST7735 bundle? Please share, thanks in advance.
Alekto46 wrote 06/02/2022 at 07:03 point
Hi
My cpu AMD Ryzen 5 3600X
Uploaded the code to esp32 lolin32 lite. The splash screen goes away and the screen goes black. I haven't been able to find the solution. Could you help.
Hardware monitor run as admin
portcqb wrote 04/23/2022 at 03:20 point
Any way to alter the monitoring app so it finds Intel 12700K temp and frequency? It monitors in other older temp monitoring apps normally but in this its not retrieving info for it only the usage percentage.
Rupert Hirst wrote 04/23/2022 at 15:58 point
Run as admin
portcqb wrote 04/23/2022 at 16:01 point
I am running as admin it reads the rtx3070 info correctly just not the 12700k info. It is possibly a windows 11 issue?
siegfried wrote 05/12/2022 at 06:45 point
Hello,
I got 12700k too, and have the same problem. I think it's because openhardwaremonitor instead of librehardware.
ant3d-zipo wrote 10/03/2023 at 07:53 point
Good afternoon! For the i7 13700 processor, the same problem. Launched on behalf of the administrator. P.S. Great project, thanks for your efforts, it works great with other computers!:)
ant3d-zipo wrote 10/25/2023 at 17:12 point
This problem occurs due to the use of HardwareSerialMonitor_v1.4.4_9600. Everything works on the old HardwareSerialMonitor_v1.4.2_9600:)
Jozsef wrote 02/24/2022 at 14:22 point
Hello I have a question, would it be possible with the sketch that I could write out less graphics but more than 1 graphics card data? I want to be able to see my RIG status through BT. This project would be the best for that.
Darwis wrote 12/23/2021 at 03:44 point
hi, thank you for your project, but i have some issue with my build, for your information my pc spec is: ryzen 9 5900, GTX 1660, Ram 64GB, ram and gpu is work like charm but gpu temp not show up, can you help me?
https://postimg.cc/yWhcXMGV <-- my bild image
thank you so much, greeting from indonesia
PS: sorry for my poor english
Rupert Hirst wrote 12/23/2021 at 18:20 point
Did you run HardwareSerialMonitor.exe as Admin ?
Darwis wrote 12/25/2021 at 10:14 point
aaah thanks man! that works!!
Darwis wrote 12/25/2021 at 10:17 point
https://ibb.co/JK47DfV
https://ibb.co/1J7Ngq6
Rupert Hirst wrote 12/26/2021 at 18:10 point
Great :)
if you select properties on the .EXE there's an option to always "run as Admin"
Could you share your Patriot Viper Ram BMP, I will add it to future versions :)
Darwis wrote 12/27/2021 at 09:31 point
thanks rupert, you can download the file, glad i can involve in your project
  https://drive.google.com/file/d/1X4qbAXxbJa9aHT4M3YmztJo0ovcmaL99/view?usp=sharing
i make that file using png file, i hope that oke.
Regrads
ynutozavr46 wrote 12/02/2021 at 22:20 point
hi, I have a problem
'packet' was not declared in this scope, connected all files, and it doesn't work((
Ömer wrote 10/28/2021 at 18:52 point
Can we add hours to the project?
Viperidae1991 wrote 10/22/2021 at 18:07 point
Thank you for this project. I made some amateur guides. Hope u like it ^^.https://www.youtube.com/playlist?list=PLMS8jHPN9vdsQ6NKmH_yelUq76Xilj5wx
Rupert Hirst wrote 10/27/2021 at 15:17 point
Thanks, I will take a look at them later :)
wivope7038 wrote 09/20/2021 at 12:54 point
Hey man, is there any 3d printable file of case and enclosure for the project and models also the ones that you put the images in the gallery?
And why don't you use HWiNFO64 instead of OpenHardwareMonitor it's got more features and support more sensors and tag then to the well known names like AUX in some motherboard as a CPU which is correct and this way you will get the cpu temp. also it's free.
Thanks in advance
tyler wrote 08/31/2021 at 03:36 point
Ooh, I am thinking about doing something similar soon. I will probably opensource my code, with docking-like features and a UI alternative as well. Let me know if you think that's something worthwhile to put out there.
ragook wrote 09/01/2021 at 20:06 point
more the merrier :)
Rupert Hirst wrote 09/01/2021 at 20:08 point
Indeed :)
tyler wrote 09/01/2021 at 21:48 point
I'm thinking support for multiple devices over LAN, and a not-connected mode where it just makes a pretty clock face and displays weather forecasts or whatever. This would be really useful for when I have my laptop at my desk vs not at my desk, so I could look over at that rather than using screen real estate.
I would want WiFi, so I'll probably just slap an OLED on an ESP32, but I'm not sure about my hardware. Anyway, I'll make a .io project if I ever do get around to making that :)
Rupert Hirst wrote 09/01/2021 at 23:34 point
You could use one of the TTGO range, ESP32 with a built in OLED or TFT.
tyler wrote 09/03/2021 at 00:07 point
Ok, I'll look into it.
obivankenobi7o7 wrote 07/31/2021 at 12:31 point
Hi, I use Xiao with ILI9341. I upload all be required library. But It gives an error even though the whole library is installed. I could not solve. Please help me
Error code this:
                                       collect2.exe: error: ld returned 1 exit status
                                       exit status 1
                                       Error compiling for board Seeeduino XIAO.
Rupert Hirst wrote 07/31/2021 at 16:00 point
Does the blink example sketch work?
obivankenobi7o7 wrote 08/01/2021 at 05:44 point
I solved problem with removing all libraries and change that new one. Thank you for attention)  last question- how to i change ram icon with corsair ram?
Rupert Hirst wrote 08/01/2021 at 14:02 point
you will have to make your own ram logo
obivankenobi7o7 wrote 08/01/2021 at 14:52 point
Okey, thanks you
rijeve3877 wrote 07/11/2021 at 20:15 point
Hi man, is there any 3d printable file of case and enclosure for the project and models also the ones that you put the images in the gallery?
Thanks in advance
Rupert Hirst wrote 07/12/2021 at 17:19 point
Not yet but i will included them soon
Agustin wrote 07/10/2021 at 09:48 point
Hi all, love this project! made my gnat-stats with a ProMicro and its amazing, i have rainmeter skin with all CPU processes and I discovered a process called WmiPvrSE.exe with constantly spikes every 3 seconds, this happens only when auto-mode is select, doesnt happen in manual mode, i changued line 91 in form.cs from:
if (isAttached)
to
if ((isAttached) && (isConnected != true))
Seems to be fine now, but i dont know if im going to break other feature like my first attempt where i uncommented line 91 and 92 with the result of Usb_DeviceAdded broken haha, my knowledge is limited in coding
Colin Russell-Conway wrote 07/15/2021 at 11:04 point
WmiPvrSE is part of the windows 10 OS that checks windows management instrumentation.  From what I can recall (its been a while since I put that together and it kind of grew organically) in auto mode it checks if the usb device is attached periodically to make sure it disconnects gracefully.  I'll have to go through the code again when I've time and figure that one out.
Lê Công Mạnh wrote 07/09/2021 at 05:11 point
Hi , everything is working fine now , but i want to change the yellow in the ram frame to red . Where do I have to fix it?
Rupert Hirst wrote 07/09/2021 at 13:28 point
 tft.drawBitmap(16, 268, Trident2_RAM_BMP, 100, 40, ILI9341_YELLOW);
to
 tft.drawBitmap(16, 268, Trident2_RAM_BMP, 100, 40, ILI9341_RED);
Lê Công Mạnh wrote 07/10/2021 at 06:56 point
Wou :O Thank you, I changed it and it's beautiful <3
Lê Công Mạnh wrote 07/05/2021 at 08:30 point
Hi I got an error hope you can help.
I use PhatStats_TFT_ATSAMD_QT-PY the screen is working properly but the GPU parameters part is not working and missing
Fan Load
Fan Speed
Power
Hope you help me <3
Rupert Hirst wrote 07/05/2021 at 23:55 point
so little info specs?
Lê Công Mạnh wrote 07/06/2021 at 01:39 point
Yes
Lê Công Mạnh wrote 07/06/2021 at 01:44 point
I want to fix this error, please help, here is the picture: https://imgur.com/a/ZHoRRah
Rupert Hirst wrote 07/06/2021 at 22:09 point
/* Remove Specific GPU items Power/Fan RPM/Fan% */
#define enable_gpuPowerStats // Nvidia Specific???
#define enable_gpuFanStats%
#define enable_gpuFanStatsRPM
Lê Công Mạnh wrote 07/07/2021 at 06:53 point
Thank you it worked :D
It works fine on desktop but when used with laptop some functions don't work. Do you have a solution?
bryant.eadon wrote 07/04/2021 at 16:41 point
Is there a use case for this in automobiles ?  Tapping into the ODBII interface, or CAN bus would be super interesting to build this into a generic "monitor this physical thing with a configurable HUD".      Given the similarities now with computers and Cars - this could really open up the doors to an interesting set of features.
