1Designing
The whole bed should look like this.
MDF build with 2 glasses shelves and led strip.
To support the frame, I design empty MDF feet on each corner. Probably the most complex part of the bed.
2Gathering all the wood pieces
3Building feet
4Building the bedhead
5Making the glass shelves with led strip
Using Dremel with abrasive head and under a trickle of water, I managed to get nice round corner and a hole for the aluminium tube.
6Painting or at least not the best way
Don't use spray paint indoors ! :)
7The frame
An aluminum U is embedded in all the edges of the structure for the final touch.
8Final assembly
Maybe little bit overkill... but that's all I found in my garage.
Here it is !
