These Musical Jack-o-lanterns (or just pumpkins, as I more often call them) are halloween props where the internals have been replaced with Addressable LEDs and then chained together to allow synchronous Audio/Light control with a computer. All the construction is intended to be weather-resistant for a setup you can leave out all season long without worrying about it.
My current setup has 9 pumpkins which are sequenced to 3 songs that plays on a 10-minute loop. The pumpkins run on 5v DC power. The speakers have their own 12v power-supply and amplifier.
![](https://cdn.hackaday.io/images/5306611696732017518.png)
The components:
- Prop Pumpkins
- IP65+ Addressable LEDs
- Weather-resistant 3-conductor pigtails & extensions
- Outdoor Speakers + Amplifier
- Housings for speakers
- Raspberry Pi (or some other dedicated computer)
- Power Supply
- Weather-resistant box
- Light sequencing software
I'll go over in more detail how everything came together, and some choices I'd make differently in retrospect.
If you'd like to see what part of my show looks like, you can view it on Youtube.
(Note that sound was added into this video after the fact, as I didn't know how to get sync'ed sound on my phone's recording and there is a bit of traffic noise on the street)
More specific information is available on the various components of the project in the project logs.
I started this project in 2021, and during the season I try to add something to improve it for veteran viewers in the neighborhood. My original blog post can be found my website: https://aaroneiche.com/2021/11/04/musical-jack-o-lanterns/
This is such a fun project. I got sidetracked by work stuff this year, so I couldn'tt get around to doing this. But I just remembered how much I liked it. I think I'm going to try to do this for Halloween 2024. Also, I've used the lights program LightShowPi (LSP) for my Christmas decorations for the past decade or so. It was really simple because it takes music, runs it through FFMPEG, and then creates the playlist. You don't have to do any programming. You just have to create the box. But that software hasn't kept up with the times (it uses WiringPi, which is no longer supported), so this might be a good time to jump to an XLights/Falcon approach.
Thank you!
MiketheChap
