Navigation
Prior Reading
Contents
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
L1 [R] Transparent HMD Options on AliExpress | L2 [T] Project too large? | L3 [M] First concept design |
L4 [M][T] 21700 and "core boards" | L5 [T] PSVITA OLED backlit Tetrinsics? |
Preface
[2024 - May 1] Named to Tetinerary.
[2023 - Nov 27]
The current project name is "Itinervate" (itinerary + innovate) because car games have been quite an influence on my thought process. The phrase "Your itinerary is being recalculated." is the most memorable phrase said by the GPS in Test Drive Unlimited 1 (and 2 IIRC), which is spoken when a destination is set/changed.
I can't see through the fog of the unknown to be able to precisely plan every event and task I'd get in the near future, so I often need to change course. When that happens, I will often think/say "My itinerary is being (re)calculated." when that happens. I mean, there are quotes like "life is a highway" and "enjoy the journey", as well as phases like "I just need a sign/direction" and the aforementioned "change course", so I may be onto something here.
Initial Thoughts
I've come to the simple yet inescapable realization that I really need some sort of life management/organizer system in place if I actually want to actually achieve my goals and ambitions in a reasonable time-frame, if at all. As an example. unlike most users on Hackaday, I've currently got over 3 dozen projects, where I still want to complete at least a dozen of them; a handful are actually large undertakings (e.g. #SecSavr Suspense [gd0105] and related projects) for a 1-man team. colour
I knew I needed it a while ago (hence projects like #TaskAttempt [gd0140] and #Tetent TimerSpy [gd0136] were started), but was lowkey under the assumption that it would just be a "nice to have" thing and not the foundational issue that affects all others.
Right now, my brain has to hold in all this information, requiring time and energy (and is self-aware that it doesn't have perfect memory, hence a bit of anxiety too) that could be going into my projects.
I've addressed the 3 key areas that I need to be able to have a full solution, with emphasis in bold:
- I need to be able to quickly add/modify tasks and timers.
- I need something to store, manage and derive information from the tasks.
- I need to be able to see the tasks/timers without friction.
- (I tried to do all 3 of these key areas with #Tetent TimerSpy [gd0136])
This project tackles the 3rd component to the solution. When I say "frictionless", what I mean is something akin to being deep in thought, quickly glancing to the wall/wrist clock to check the time, and then going back into thought.
There's also an implied overarching requirement, which is that the solution needs to be available the vast majority of the time, as I have new ideas, decisions and considerations the vast majority of the time. I'm essentially trying to offload what my brain is currently trying to do, and thus I can't just landlock the solution to my desktop PC #Teti [gd0022], and I think a HUD/HMD is a bit more practical than mounting a phone stand / selfie stick to my body. Expected moments of downtime are showering and sleeping.
In the most ideal case, the solution would be something I could actually call my "second brain" that apps like Obsidian help users create.
