CRTFORPX.INF.txt
Info for a similar, but homegrown project, intended for an IBM monochrome monitor. The original file is called ''crtforpx.lbr'' and was found at http://cerealport.homeip.net/cereal/px8/. The file was corrupt or made with a unknown version of the LBR compression program, so the included drivers are lost.
plain - 14.23 kB - 05/11/2024 at 18:51
Download
reUD80V0.10-signalScreenshots.zip
Some screenshots of the scope screen of signals of a properly working Re-UD-80. See the log "Debugging a problem board".
Zip Archive - 201.52 kB - 04/01/2024 at 11:37
Download
re-UD-80_Case.zip
New set of 3D printer files. Improved button hole size and location, added a front panel without RGB-DIN hole.
Zip Archive - 199.99 kB - 04/01/2024 at 10:51
Download
oval80replicaV0.10_bom.zip
The BOM with remarks from brijohn@forum.vcfed.org.
Thanks!
Zip Archive - 1.81 kB - 03/30/2024 at 16:35
Download
oval80replicaV0.10.connectors.pdf
External connector and jumper info.
Adobe Portable Document Format - 1.15 MB - 03/30/2024 at 16:33
Preview
Download
oval80replica0.10.kicad.zip
KiCAD 6.0 design files, including some custom libraries for vintage symbols and footprints.
Zip Archive - 336.67 kB - 03/02/2024 at 17:24
Download
ud80_rom7.11composite.zip
Patched 7.11A ROM to generate composite sync, making it compatible with the RE-UD-80 v0.10 board. Includes a dissassembly with some annotations used to find the proper configuration bits.
Zip Archive - 48.58 kB - 03/02/2024 at 07:29
Download
UD80_rom5_21-low.lst
Partial disassembly of the 5.21E ROM.
lst - 303.17 kB - 02/24/2024 at 20:33
Download
The case is designed to fit around the board with small tolerances. No internal mounting is required when the case is closed.
JPEG Image - 136.46 kB - 02/24/2024 at 11:43
Preview
Download
reUD80box1.zip
3D printer files, object files for top and bottom case, front and back panels. This case fits the version 0.10 PCB exactly.
Zip Archive - 172.31 kB - 02/23/2024 at 20:48
Download
oval80replicaV0.10.csv
Component list as produced by KiCAD
Comma-Separated Values - 2.54 kB - 01/10/2024 at 09:50
Download
oval80replicaV0.10.kicad_sch.pdf
The final 0.10 schema
Adobe Portable Document Format - 188.66 kB - 01/10/2024 at 09:46
Preview
Download
oval80replicaV0.10.kicad_prod.zip
The file set as send to the PCB-manufacturer
Zip Archive - 85.27 kB - 01/10/2024 at 09:40
Download
The prototype board that actual worked after fixing embarrassingly mistakes on the back side. The board is a modified version 0.8.
JPEG Image - 278.82 kB - 12/30/2023 at 21:12
Preview
Download
UD80_ROMS.zip
Oval ROMs for the UD-80 and DS-8. The 5.21E ROM contains drivers for the PX-8, the 7.11A drivers for the PX-4. The DS-8 driver is an other Oval device allowing for both a printer and a UD-80 on the same RS-232c port.
Zip Archive - 18.43 kB - 12/30/2023 at 21:08
Download
ud80_ec198603.pdf
A review of the original UD-80 in the Epson Connection magazine of March 1986
Adobe Portable Document Format - 948.08 kB - 12/23/2023 at 21:17
Preview
Download
