The software used by the Modular Pi Cam 2 (mpi cam 2) is mostly the same as the Pi Zero HQ cam with some upgrades like different display and detecting camera.
A Raspberry Pi based camera that can swap body parts and camera modules
I got some better shots
I have some code in progress now, not sure if I'll get it done today/soon.
Will address:
- USB file transfer (no wifi network needed eg. sftp)
- delete all camera/video files from menu choice
- reset battery from menu choice (vs. current percentage check)
So I went out and used this thing as I normally would with any other camera (Nex 5n, A7 II or A7R III). I'm not a professional photographer, I just like going to the park and shooting macro.
Can see I shot 72 images or tried to some failed.
Today was spurred on by my investigation/comparison of two 16mm telephoto (blue ring) lenses to see if I got a bad batch (first one) or if this is how they are (bad bokeh/highlight at low aperture).
As far as how many I consider good/came out... let's see.
I also want to note, the auto light/color balance was not good sometimes... if I was looking towards the sun it would get so dark all the colors would be lost eg. green grass. Which I know that is a thing but still.
First impressions of photos...
F1.8 is pretty soft for some reason, 2.8 is good
Bee midflight
1.4 or that area blooming?
Heron on a tree, I didn't have the reach sadly
This one's cool
This one's nice
Bumblee
The issue is not as prominent here so I think this lens is better
Last pic
Here's a bonus video
I shoot these blind (no live preview) because I have to figure out how to do that with the SPI display.
I will say... I'm still generally unsatisfied with these photos, the quality specifically. I still have to get one of the "real lens" adapters and use a real camera lens to see if that helps but it may just be the sensor too. My specific use case is putting my photos on my 32" 1440P ultrawide monitor and the photos on there now are from 16MP, 24MP and 42MP cameras... and real glass so not fair but yeah.
Got some decent shots, only used the Arducam 8-50mm. I did buy a second 16mm telephoto lens to see if the crazy highlights are just how the lens are or if I got a bad one. That's still being shipped.
I think these two were the best shot of the day though
Full res links
OMG... it's intercepting the links and embedding them
Sort of
This time most of the pictures saved vs. almost none
I have to add this file size check
I almost thought when I got the field that it was broken, since I stopped a battery profiling test (takes hours eg. 8) but thankfully it was working still, had to get past a white screen, probably a white on white text to background situation.
Got some cool shots though.
The v3 ultrawide was disappointing, damn... at least stretched out, too much detail.
Some pics from camera/lenses
There's a weird w shape distortion with the wide, idk it's easier to tell when you have uniform lines
The 16mm telephoto lens has some really nasty bright spots idk how to explain it, I'm not sure if the one I got is bad or this is just how it is... next time I have $50 to drop I'll get another one to test.
This could be a cool pic if it didn't have the crazy background branches popping out of the blur
I don't want to say it, but I think right now the 8-50mm arducam lens is the best lens I have for the HQ cam. The 16mm just has correct color vs. the 8-50mm (slight purple tint).
Here's an 8-50mm shot in comparison
The v3-standard was the best though I also hate to say since the HQ cam supposedly will have legit lenses.
These trees are called "red buds"
Cool macro vibes here v3 standard again
Last frame from sunset timelapse which was bad since I had 25 mins left of light and each photo was taken every 5 mins ha.
I was concerned this camera (orange) wouldn't be used much like the Pi Zero HQ cam with the v2 modular pi cam being the main camera I'm using now.
I started doing the face capture in videos recently for code-heavy content.
Simple V-shape design goes around a stick/tightens with a screw
The stick I just taped to the back of my ultra wide monitor stand
Initially I just used the ML Clip Cam on there
Like this with the video output rotated via CSS
Wow... the first attempt was completely wrong damn... I was not paying attention
I used the diameter as a radius
This works, it points (sags) downwards too
I just quickly inverted colors and menu sprites so I would have light mode, maybe will help in daylight since the LCD is pretty dim.
Bad code man... also I picked up a nail in my car tire at the park... great
Really bad... almost none of the pictures saved... oh man
I wonder what it is... I guess I should have tested it more
21 photos failed out of 25 damn that's bad
But I got some cool pics of the body on a a rock
Oh man...
The only thing that worked is the video mode
I don't want to say it but I should not have gone out today damn
I did notice that after the photo was taken the preivew was not resuming
Here it is with a wide angle v3 module
I am not joking when I say almost all the images fail... something is seriously wrong with this code, I made too many modifications at once.
The ones that saved were bad. The red buds are coming out though. I took photos of that and those also failed lol damn.
You can tell which lens took this (16mm), due to the nasty highlights
The flat tire
Working on a video though it's mostly external footage other than the onboard video that did save. Nothing crazy probably ugly panning 720p shots
So many words...
These little caps are cute for the v3 modules
Will go out to the park tomorrow
Video and pull request
https://github.com/jdc-cunningham/modular-pi-cam/pull/5
This code is still bad but it'll work for tomorrow, has camera detection and dynamic feature eg. text overlay with focus diopter value in the case of the v3 module
Not as fancy as I originally designed, just wanted to get it done, in total about 9-10 hrs to print the 3 parts (includes lens cap).
I did start working on some code refactor/modification but that'll be tomorrow then to the park on Wednesday.
I forgot this, did battery profiling/charge, the failed design gap is kind of cool
I realized the switch was in the wrong place, so I had to crack it open and change that.
So the switch is on the output between BMS out and DC in vs. between battery and BMS.
Anyway I will work on the zoom code next then add in the camera detection/overlay then take it out sometime next week probably Wednesday least crappy day that I have off weather wise.
Will have to work on Pelicam but I have to sit down and think for that one.
The brief experience so far of changing from the 128x128 OLED to 240x320 LCD (portrait) showed how difficult it is to make a multi-hardware camera interface.
Tomorrow I'll design the lens wrappers around the 16mm blue ring lens. I was thinking about adding an RFID to them so I could tell in code which lens was attached. Not something I'll do anytime soon.
At the very least I'm going to see if there is a way to add notches to tell f-stop but probably won't be a thing... just use live preview out to check if image looks good.
j
