This started out as just me wanting to try round displays and the 5D directional pad... but as I worked on the project I realized the body could be modular eg. swap the camera module/front plate or back plate.
Details
The software used by the Modular Pi Cam 2 (mpi cam 2) is mostly the same as the Pi Zero HQ cam with some upgrades like different display and detecting camera.
I'm starting to envision the next stage as I use this camera more and more
More cameras...
For some reason the color yellow... is in my mind
And a flip display/camcorder style plus sliding rail stabilizer for the lens so videos look better... may make more sense to have an outside/full body gimbal but still. Because the sensor one also has to hold up lenses attached to it.
Oh yeah the other thing is small steppers that autofocus the lens. I've done some work with that (laplace).
So I went out and used this thing as I normally would with any other camera (Nex 5n, A7 II or A7R III). I'm not a professional photographer, I just like going to the park and shooting macro.
Can see I shot 72 images or tried to some failed.
Today was spurred on by my investigation/comparison of two 16mm telephoto (blue ring) lenses to see if I got a bad batch (first one) or if this is how they are (bad bokeh/highlight at low aperture).
As far as how many I consider good/came out... let's see.
I also want to note, the auto light/color balance was not good sometimes... if I was looking towards the sun it would get so dark all the colors would be lost eg. green grass. Which I know that is a thing but still.
First impressions of photos...
F1.8 is pretty soft for some reason, 2.8 is good
Bee midflight
1.4 or that area blooming?
Heron on a tree, I didn't have the reach sadly
This one's cool
This one's nice
Bumblee
The issue is not as prominent here so I think this lens is better
Last pic
Here's a bonus video
I shoot these blind (no live preview) because I have to figure out how to do that with the SPI display.
I will say... I'm still generally unsatisfied with these photos, the quality specifically. I still have to get one of the "real lens" adapters and use a real camera lens to see if that helps but it may just be the sensor too. My specific use case is putting my photos on my 32" 1440P ultrawide monitor and the photos on there now are from 16MP, 24MP and 42MP cameras... and real glass so not fair but yeah.
Got some decent shots, only used the Arducam 8-50mm. I did buy a second 16mm telephoto lens to see if the crazy highlights are just how the lens are or if I got a bad one. That's still being shipped.
I think these two were the best shot of the day though
Full res links
OMG... it's intercepting the links and embedding them
This time most of the pictures saved vs. almost none
I have to add this file size check
I almost thought when I got the field that it was broken, since I stopped a battery profiling test (takes hours eg. 8) but thankfully it was working still, had to get past a white screen, probably a white on white text to background situation.
Got some cool shots though.
The v3 ultrawide was disappointing, damn... at least stretched out, too much detail.
Some pics from camera/lenses
There's a weird w shape distortion with the wide, idk it's easier to tell when you have uniform lines
The 16mm telephoto lens has some really nasty bright spots idk how to explain it, I'm not sure if the one I got is bad or this is just how it is... next time I have $50 to drop I'll get another one to test.
This could be a cool pic if it didn't have the crazy background branches popping out of the blur
I don't want to say it, but I think right now the 8-50mm arducam lens is the best lens I have for the HQ cam. The 16mm just has correct color vs. the 8-50mm (slight purple tint).
Here's an 8-50mm shot in comparison
The v3-standard was the best though I also hate to say since the HQ cam supposedly will have legit lenses.
These trees are called "red buds"
Cool macro vibes here v3 standard again
Last frame from sunset timelapse which was bad since I had 25 mins left of light and each photo was taken every 5 mins ha.
j
